Solvent extraction, as the name clearly shows the process of extracting oil from the oil bearing materials with the help of solvent. Normally a by product of petroleum is used as a solvent.
Let’s understand about the solvent extraction plants
Solvent extraction plants are used in extracting oil with the help of using chemicals. The cake which is obtained from the oil press section is used by these plants. And to dissolve the cake’s oil and seed’s oil an organic solvent used after the process of dipping and spraying, which ensures the close contact of the oil content with the feeding material. After this, the oil is collected and the solvent gets vaporized. The specialty of these plants is the solvent that is vaporised and can be recycled. so this plant gives the benefit of recycling solvent to your oil mill industry.
There are many manufacturers of solvent extraction plants, but we at Shreeji expeller industries use the quality assured material and advanced technology in the manufacturing and fabrication process of oil expellers. We have designed these plants for the up-gradation of the oil mill industry, especially for oil extracting directly from the oil seeds that have less than 20% in them such as soybean after the flaking process. Pre pressed or fully pressed cake seed that has over 20% of oil in them such as cotton seeds, palm kernel, copra, peanuts, sunflower, castor, and much more.
Procedures to be followed in the solvent extraction process:
- Dip oil-rich flake or cake which is pre-pressed transform into the solvent
- Dissolve oil from vegetable and transform into the chemical solvent
- Filtration of solid material
- Evaporated oil mixed solvent transforms into the solvent or separate oil.
- Cool and recycle the solvent
- Further processing of oil and cake.
- The best attribute of the solvent extraction plant is that it provides a simple transformation-over of the process materials. These plants are also used in assorted industries to make use of the extraction of various useful solvents.
Salient features of the standard solvent extraction plants:
- These plants are available in different forms such as solid to liquid and liquid to liquid extraction systems.
- Solvent extraction plants in oil mills use energies such as polar or nonpolar or a combination of both.
- There is a Versatility in the processing of all types of seeds, bran or oil cakes
Shree Ji expeller’s best offering at the most affordable rate with premium quality and advanced technology.
You can understand now how technology changes everything right from oil mills to refinery solutions. Our one of the most advanced inventions is oilseed mills. These mills perfectly take away the impurities. At Shreeji, you will find premium quality and durable oil expellers for your oil mill industry. We construct the oil mills with robust and advanced equipment which have all the required facilities, resources, and components that are required for oil processing. Shreeji expeller industries offered solvent extraction plant has a capacity of 50 TPD to 2000TPD. And our plants consist of the seed preparatory section, distillation section, solvent extraction section, meal de- solventising section, meal conditioning section, and recuperation section.
