2N2222A Transistor Datasheet
daenorthughdaenorthugh wrote 10/27/2021 at 03:00 • 2 min read • Like
Product Overview
2N2222A is a NPN transistor hence the collector and emitter will be left open (Reverse biased) when the base pin is held at ground and will be closed (Forward biased) when a signal is provided to base pin. 2N2222A has a gain value of 110 to 800, this value determines the amplification capacity of the transistor. The maximum amount of current that could flow through the Collector pin is 800mA, hence we cannot connect loads that consume more than 800mA using this transistor. To bias a transistor we have to supply current to base pin, this current (IB) should be limited to 5mA.
 2N2222A Pinout
This blog will introduce 2N2222A systematically from its features, pinout to its specifications, applications, also including 2N2222A datasheet and so much more.
2N2222A Features
2N2222A Pinout
The pin configuration of the 2N2222A transistor is shown below. This transistor includes three pins & its each pin functionality is discussed below.
2N2222A Pinout
2N2222A Advantages
The main advantages of using the 2N2222 transistor include the following.
If you want to know more about 2N2222A, you can read its datasheet.
Like
