Tiniest mobo for a e-ink reader ?
v1nce wrote 11/05/2021 at 16:06 • 1 point(This is my first post, I hope I don't break any rule)
I'm looking for the TINIEST realistic motherboard and battery to make some kind of e-reader :
drive a 8" e-ink screen (normal refresh rate);
high polling rate for the digitizer (>= 180Hz);
display e-book on it (zoom, prev/next page, annotations);
4 hours of usage on battery will be fine. 2 will be ok (and unlimited if usb powered);
being able to run app is an option but not mandatory;
Do you know of some crazy projects (e-watch mobo + lvds driver) I could have a look at ?
Thank you. Weight of this e-reader is very good and it looks very capable. But my problem is more with the motherboard size. I got no problem with the weight or size of the screen. The problem is with the mother board that should be "apart" from the screen (ribbon)
Try this: https://inkplate.io/
i hate e-ink but like mirasol
The Open Book project is a complete, hackable e-reader with a 7" screen. It comes in two flavors, one utilizing a ATSAMD51 microprocessor, and the "Wing" version one utilizing an easier-to-solder Feather microcontroller. Check out the schematic and BOM, should give a good idea of what you're in for if you try to build your own (or, you could just go with the Open Book...)
https://www.tindie.com/stores/joeycastillo/
I have exactly what you need:
https://hackaday.io/search?term=e-ink&category=project%20project&tag=e-ink
https://hackaday.io/search?term=e-ink&category=project%20project&tag=epaper
