COSEL Co, Ltd (6905: Tokyo) today announced the expansion of its medical power offerings by adding 300W power of COSEL Co, Ltd's PJMA series.
Features:
- I/O isolation: 4kV
Extra-wide temperature of operation that is : -20degC to 70degC
The input for universal use is 85V264V AC
- It supports applications that use BF (Body Floating) applications
- Low power consumption there is no load
If you require an efficient power supply, the latest PJMA offers a very high cost-to-quality proportion due to its solid platform design. The PJMA can be adjusted by the built-in potentiometer output voltage can be found in four levels (12 24, 36 as well as 48 VDC).
For protection techniques, the PJMA series is enhanced with inrush current limiting, overcurrent/overvoltage, and thermal protection. In terms of EMC testing, devices from the family comply with the EN55032-B, EN55011B, CISPR32B FCC-B, CISPR11-B, and the VCCI-B. Additionally, an additional EMI filter COSEL type NAC could be used for devices required to have lower emission levels.
It is a part of the PJMA series is enclosed in a galvanized steel case with a fan behind the box to increase its strength and long-lasting. The PJMA300F is a weight limit that is 1.0 kg and dimensions of 102 x 41 x 193mm [4.02 x 1.61 7.48 inches]. 7.48 inches[4.02 x 1.61 x 7.48 inches] (W by H by D).
The PJMA series has a five-year warranty as well as being RoHS, REACH as well as Low Voltage Directive conforming.
With the introduction of the PJMA300F model, it has expanded the PJMA series now has models with a range of 300W up all the way to 1,000W (PJMA1000F) and also 600W models (PJMA600F).
About Cosel
Cosel Co Ltd has been an important global manufacturer of switch-mode power supplies and EMF filters since 1969. Cosel produces and produces tiny high-efficiency DC/DC and AC/DC devices for medical and ITE applications that utilize the latest technology and designs. AC/DC products vary from 3W to 10KW for board-level, open frame, DIN Rail, Modular and enclosed versions. With power levels that range in the range of 1.5W and up, the DC/DC units are available in board-level as well as DIN rail mount models. EMI Filters come in a variety of sizes, from 3A to 600A, with photovoltaic-specific variants available. Many EMI Filters can also be installed on the DIN rail. Cosel's immediate field support and exceptional engineering support assist our customers."
