Quick and dirty paint heat stress test
Stefan LochbrunnerStefan Lochbrunner wrote 09/06/2015 at 20:06 • 2 min read • Like
Regarding David's PCB fabrication process (for #DNA-LAMP Diagnostic Device) I asked if he tried using the black spray paint also as solder mask. While he doubted the paint would survive the soldering temperatures I thought it would. Of course this depends on the type of spray paint (and probably other variables), but I was just curious to see if the cheapest one from my local hardware store would be up to the task. Therefore, in order to find out if spray paint is a viable candidate for cheap and easy DIY solder mask I did a quick and dirty test to see how the paint behaves when heated to typical soldering temperatures and this is the result:
I applied some solder and kept the soldering iron on there for way longer than would be necessary to solder a component. While heating the copper small bubbles formed at the border of the copper area, like the ones indicated by the arrow, but almost all of them disappeared again. I think the bubbles might be due to some residual moisture since I didn't let the paint dry for the recommended amount of time.
The masking wasn't that great, which is why some paint wicked itself under the masking tape between some copper strips as can be seen in the bottom left. These residues seemed to melt when heating the copper but the main layer of paint seems unaffected.
A quick continuity check showed no short-circuits between neighboring copper strips and measuring the resistance proved that the paint forms an electrically insulating layer (no surprise there but I thought I'd mentioned it for completeness). However, this single coat of paint doesn't stand up against mechanical damage very well and can be scraped off quite easily. Multiple coats of paint and adequate drying might be required to address this.
From this quick test I think spray paint might work as makeshift DIY solder mask and I am very excited to see how David's test turns out.
Like
esot.eric wrote 09/07/2015 at 04:35 point
Nice, but next time use a color that doesn't look like it's burnt ;)
Glad to see this experiment, for sure!
Another cool thing, I think, about this combined with the laser-etching is that the etch-blocking paint needn't be removed, just throw on another layer and laser-etch the pads.
Stefan Lochbrunner wrote 09/07/2015 at 10:09 point
Thanks! Yeah, I thought the same thing about it looking burnt :)
I also think It wouldn't look as bad if I only heated it for a shorter time. I thought about cleaning it after soldering but the paint isn't resistant to acetone, which is quite a disadvantage.
Speaking of color, you could also make a multicolored board, one color for AC another for DC for example. But then this takes away some of the simplicity of being able to just spray another layer on the etched board, which is certainly convenient.
esot.eric wrote 09/07/2015 at 15:51 point
Hah multicolor solder-mask!
