P89V664FA Microcontrollers Datasheet
daenorthughdaenorthugh wrote 04/06/2022 at 09:22 • 2 min read • Like
Product Overview
The P89V660/662/664 are 80C51 microcontrollers with 16 kB/32 kB/64 kB flash and 512 B/1 kB/2 kB of data RAM. These devices are designed to be drop-in and software compatible replacements for the P89C660/662/664 devices. Both the In-System Programming (ISP) and In-Application Programming (IAP) boot codes are upward compatible.
Additional features of the P89V660/662/664 devices when compared to the P89C660/662/664 devices are the inclusion of a secondary 100 kHz byte-wide I2C-bus interface, an SPI interface, four addition I/O pins (Port 4), and the ability to erase code memory in 128-byte pages.
The IAP capability combined with the 128-byte page size allows for efficient use of the code memory for non-volatile data storage.
This blog will introduce P89V664FA systematically from its features, pinout to its specifications, applications, also including P89V664FA datasheet and so much more.
P89V664FA Features
Principal features
Additional features
P89V664FA Pinout
The following figure is the diagram of P89V664FA pinout.
P89V664FA Pinout
Like
