This article is about cooking baked shrimp.
Those are the ingredients that you will need:
Frozen Shrimps:
Celery:
Frozen Vegetables:
Frozen Peas:
Onions:
You will also need a metal or glass dish that you will put in the oven:
Step 1: Cut the Celery
Step 2: Cut the Onion
Step 3: Put Inside the Dish
Step 4: Put Inside the Oven
Set the oven to a temperature of 150 degrees and the time of half an hour:
Make sure you check after 20 minutes to see if your dish is ready:
Step 5: Take Out of the Oven
Step 6: Add Tomato Sauce
If the tomato sauce is from the fridge then you do not need to let the dish cool.
Crazy Recipes
