The Mirror Cube or also known as Bump Cube is one of the most attractive puzzle to mess up, and to finish. Like the Rubik's Cube, the Mirror Cube is understood the same way, its a genuine Rubik's product. be that as it may, as you see the diverse between the 3D shapes is that one has hues as alternate has shape with distinctive sides.Its an uncommon shape-moving puzzle which look amazingly cool.
The Mirror shape is more hard to explain than the first Rubik's Cube, as the first give shading prompt and you'd need to depend on the sizes of the squares rather, however in the event that you can understand the first one you'd have the capacity to unravel this one. One simple way would be to illuminate the biggest pieces first as though they are on the first layer.
The pieces are a touch harder to turn. It is not spring-stacked and you can't modify the strain like a rate 3D shape. The rugged way of the 3D square makes it harder to adjust the pieces too some of the time. The material used to make this block is the same as the first non-speed cube.
Lucky for me, i know how to solve the Rubik's Cube, which hopefully means i may have it easier to solve the Mirror Cube, i place a order on Amazon for my Cube and plan to spend as must time to learn how to solve it to look very cool. After i hope to buy a glowing green edition of the puzzle so it looks like a shape-shifting kryptonite.
If you know any other cool puzzle or things, just tell me in the comments below.
Mirror/Bump Cube short video review:
