I think that it is an assortment. It isn't real clear to me either. One thing that I saw a few minutes ago, just the tips : V9000K8-B To rotate the nozzle, I would put a straight piece of brass tubing down through a couple of bearings and put a gear on it to rotate it. Put the soft tip on one end of the brass tube. Hook up the vacuum on the other end with a piece of Tygon or vinyl tube. Limit the rotation angle to +/-180 degrees in software to prevent users from twisting up the Tygon tubing.
Digikey has some soft vacuum pickup tips: http://www.digikey.com/product-detail/en/VCS-9-B/VCS-9-B-ND/3528157
Thanks! How would one rotate these nozzles? Also, it's not clear - is this a 9-pack of assorted nozzles?...
