Big Robot Platform - Need Suggestions - LIDAR, Thermal Camera, Treads, Motors, Batteries Weight >300Kg
ZaidPirwani wrote 04/12/2016 at 10:01 • 0 pointsSo I am working on a project funded by my university to make an autonomous/manual fire fighting robot (actual size), equipped with all sorts of neat things.
LIDAR,
Thermal Camera,
Arm Gripper to Hold a Fire Snorkle/Nozzle,
Tank Treads for moving on about all sorts of urban off road terrain.
It has to do obstacle avoidance, somewhat mapping of the area, Wireless Control/Monitoring and such.
I have seen similar bots online, all are huge and heavy, 200Kg or more, some even 700Kg, my university will be funding me for this for maybe something around a big 300Kg robot.
I have no idea of motor and battery selection for such a robot, looking at 2hour or more battery life.
Any ideas people.??? THANKS.
2 hours battery life - under what conditions? you need to describe the usage scenario - standing draw (for electronics), moving draw for the motors.
to get 2 hours constant motion, you are going to need a hell of a lot of battery for something that tips at 300+kg, or use a small generator system, which will add even more weight.
this is going to be a nontrivial build, I can tell that much from the start
well, much has changed, the robot they showed me earlier to mimic was Parosha Cheeta GoSafer, now, the design and specs have changed to a smaller variant, possibly no LIDAR, Thermal is still okay. Going for something like the HD2 bot at superdroidrobots.com
also, the weight has gone down a lot too.. I am expecting the bot to be 50Kg now..
That's comparable to FIRST Robotics, so I suggest you go check usfirst.org and look up "frc" for ideas
autodefibrillator
If you are saying to include that in the bot... Then I can't.
