Best pump for brake fluid?
TazwellJ wrote 05/10/2023 at 18:19 • 0 pointsThinking of making a brake bleeding system using Pi Picos, pumps and LoRa. Why? Because I'm bored, hate bleeding brake lines and want to learn to use LoRa. Essentially I want to be able to stand back and push buttons on a remote to turn on the pumps individually or in combination.
I'm thinking peristaltic pumps. Thoughts? Suggestions?
Is the LoRa overkill? Maybe just go bluetooth?
ask
Hello Everyone!
Peristaltic pumps are good for pumping brake fluid in a brake bleeding system. They are designed for fluid transfer and can handle brake fluid without direct contact.
Regarding remote control, consider your specific requirements. If you need long-range communication or operate in areas with limited connectivity, choose LoRa. If you prefer simplicity and shorter-range connectivity, go with Bluetooth.
Thanks for the input!
for what brake system do you want to build that? A bicycle brake will be different to bleed to a old car or a modern car or even a truck...
Look at the commercial brake bleeding systems, some of them just apply a slight overpressure on the reservoir and use that to push the brake fluid. Therefore no pump is needed, as shops have air pressure, it just needs a pressure regulator.
And on some modern cars nothing at all is needed as you can bleed with the ABS system, just hook a PC up. On such cars it can be that you must do it this way, otherwise not all channels inside the ABS system get flushed.
If you want to actually pump brakefluid make shure all materials are resistant against it, its a nasty thing.
It was for a '77 Jeep CJ-7 that's jacked up pretty high. I have to replace a valve in the brake system so the entire system has to be bled.
All of it is overkill ;) You could do this with a cable, dc motors and some switches. Bluetooth would probably be more overkill than lora (due to protocol simplicity), but lora is also overkill unless you need to bleed brake fluid from a kilometer away. Cheap wifi module or any 433 radio will probably suffice. Brake fluid should probably not be very conductive, so you can even have immersed motors with impellers to pump it, but for bleeding probably peristaltics are the best.
Yeah I was thinking the peristaltic mostly for cleanup afterward since the fluid would never actually be in contact with the pump. The easiest for the wireless would probably be just to get Pico W's and put a small web server on each one.
This may all be a moot point though. I realized last night that the vehicle I was thinking of building this for sits up so high that it's hard to get one tire off the ground with a normal jack, let alone all 4 at the same time. That is unless I change Step 1 of the project to: "Buy a commercial vehicle lift"
Thanks for the input anyway!
