Single Sided
danjovicdanjovic wrote 12/01/2016 at 21:28 • 1 min read • Like
After reading this post from @Radomir Dopieralski I couldn't help the challenge and completed the single sided version of the #Servo Breakout for WeMos D1 Mini board.
UPDATE: 3V/5V selection
Like
deʃhipu wrote 12/01/2016 at 22:36 point
Nice! You even added pullups for the address jumpers! I see you are powering the whole thing with the same power as the servos -- I was afraid of noise on that power line, so I tapped the 3.3V pin on the D1 Mini instead. I guess it doesn't matter for I2C, as long as the logic high is compatible for both. I also tried to make the 5V connection a single trace, so that it can be easily cut, and then you can power the servos separately from the D1.
In any case, great job!
danjovic wrote 12/02/2016 at 02:13 point
Thanks! If you wish I can send you the Eagle files. I think it is possible to power the AVR from 3Volts as well..
If you received this message several times, nevermind, that was my mobile phone phreaking out, lol!!
deʃhipu wrote 12/02/2016 at 09:11 point
Thank you. I don't intend to actually use any of those single-sided designs, it was done purely to see if it's possible. I have a two-sided design that I plan to use -- since practically all fabrication services do double-sided boards anyways, and this is too intricate to etch by myself.
