Arduino-programmable ARM Cortex M4F Boards
oshparkoshpark wrote 12/30/2016 at 21:05 • 3 min read • Like
@Kris Winer of Pesky Products designed these easy-to-program, high-performance and low-power dev boards:
screenshot-at-2016-12-19-18-21-29Arduino-programmable Cortex M4F Development Boards
Program an STM32L4 Cortex M4F with the Arduino IDE via USB
07d323cc59a7037a2ce3db223c0fdf7d_original-jpg
Technical specifications of the Butterfly and Ladybug STM32L4 dev boards:
New Butterfly and Ladybug add-on boards
57b2768c5f3f65c565cb477bb7899e9a_original
To the left is an MPU9250 accel/gyro/magnetometer motion sensor and the BME280 pressure/humidity/temperature sensor
To the right is an ESP8266 wifi-enabled add-on board for Butterfly
Ladybug environmental data logger
Reading the BME280 and VEML6040 sensors at 0.5 Hz and outputting pressure, temperature, humidity, altitude, RGB light intensity and RTC time and date to the Sharp memory display
Simple designs make hardware customization easy
c2e3de0f40183339cd72afecdd487e5a_original
Flight Controller:
STM32L432 receives quaternions from the EM7180, which itself is master to the motion and pressure sensors, GNSS data from the CAM M8Q, then processes and packages the data and sends it to the ESP8285 via UART bridge for transmission to a hand-held controller
9627aadfc8bbc07331533d6a13b697b3_original
Industrial Diagnostics:
uses an STM32L433 as master to several slave sensors to detect and process signals from industrial equipment and report to a remote server via blue tooth
Like
