Cypress FX2LP High-Speed USB Controller
oshparkoshpark wrote 02/07/2017 at 18:54 • 2 min read • Like
@Yin Zhong designed this dev board for Cypress FX2LP microcontroller:
750471485341005936-1
μ-68013: a High Speed USB2.0 MCU breakout
Cypress’s FX2LP (CY7C6801x) is one of the smallest footprint MCUs that offer a high-speed USB (480 Mbit/s) device peripheral with built-in PHY (many others lack the PHY!). It contains a 8051 core for bookkeeping and setting up data streams through its hardware multiplexed parallel FIFO interface to/from an external processor, be it MCU, DSP, or FPGA/CPLD.
This is a breadboard-friendly minimal system PCB for CY7C68013 in QFN56 package. It integrates 3.3 V power supply, core clock, reset circuit/button, and I2C EEPROM (the MCU does not have built-in flash). It breaks out all IO pins through 2 rows x 20 pins 0.1″ pitch headers with 0.7″ row spacing.
summivox has shared the board on OSH Park:
20170112-0057 CY7C68013-v1.0.zip
3ff564ec93a66d415384b740fe7db92f.png Order from OSH Park
Like
