DTV Tuner Breakout for SDR
oshparkoshpark wrote 03/01/2017 at 09:15 • 2 min read • Like
Eric Brombaugh designed this breakout board for the Rafael Microelectronics R820T2 Advanced Digital TV Silicon Tuner chip:
r820t2_breakout_assembled
R820T2 Breakout
This is the same chip used in most all of the RTL-SDR dongles, as well as the Airspy and numerous other radios. The chip is a versatile front-end with reasonable sensitivity and wide tuning range.
screenshot-at-2017-02-17-13-54-36
The design presented here is almost an exact implementation of the Mfg’s suggested demo design from the datasheet, implemented on the OSHpark 4-layer PCB process and provides a simple 4-pin interface with power, ground and I2C bus for controlling the tuner. A broad-band RF input and 10MHz IF output are provided on SMA connectors.
The breakout PCB design and STM32F0 firmware for the Rafael R820T2 tuner chip are shared on GitHub:
emeb/r820t2
emeb has shared project on OSH Park:
r820t2_breakout v0.1
Order from OSH Park
Like
