ECC83S and EL84 : huh ?
Yann Guidon / YGDES wrote 03/10/2017 at 15:45 0 points
Apparently, one of my neighbours has "revalved" his amp.
I'm surrounded by musicians so apparently, one of them has changed all the chinese tubes with slovak ones. He conveniently left the original tubes in the common space. I end up with (equivalents of) 4×ECC83S (preamp ?) and 4×EL84 (amp ?) of unknown vintage. Some might be disfunctional, no trace of dust or heat, only one might have burned inside, a bit. One might have burned and the guy changed the whole set "because you never know".
WTF do I do with that ?
I'm not a tube/valve amateur and I loathe any component that heat and/or requires high voltages (doesn't bode well, huh ?) but the temptation is latent.
Analog circuits would be too messy and useless. I have plenty of fun ahead with my relays (as wel as the many germanium and silicon transistors) and it's out of question to start a computing project with tubes. However I think a demo project with a few of them, maybe an ECL-equivalent logic gate, would serve as an "educational resource" (as in: you see, keeds, grand-grand-dad used to rely on these glowing hot dangerous things, before the transistor came to the rescue)
Since I have no idea of the specs (I could google them I know), and 8 tubes (or realistically maybe 6) is very limited, can anybody help and hint at practical, interesting and/or useful applications ?
Something with an oscillator, a latch, a logic gate...
