Digital IC tester(for industries and engineering colleges)
shubham-kumarshubham kumar wrote 04/28/2017 at 18:55 • 1 min read • Like
https://www.instructables.com/id/Digital-IC-Tester-for-Industries-and-Engineering-C/
https://in..com/in/shubham-kumar-746b84108
IC’s, the main component of each and every electronic circuit can be used for wide variety of purposes and functions. But sometime due to faulty ICs the circuit doesn’t work. Indeed it is lot tedious work to debug the circuit and confirm whether the circuiting is creating problem or the IC itself is dead. So to come up with these sorts of problems IC tester confirm whether the IC under consideration is working properly or not.
Contact:
Shubham kumar
Shubham2ece@gmail.com
https://in.linkedin.com/in/shubham-kumar-746b84108
ECE ,UIET Hoshiarpur,PUSSGRC,Panjab University
Like
