API wrapper for hack.chat using ws package - Hack Chat of https://www.npmjs.com
Usage
var HackChat = ;var chat = ; // Client group for multiple channels
chat;
var programmingSession = chat;
chat
chat
HackChat.Session methods
new(channel: string, username: string, password?: string, options?: any = { server: "wss://hack.chat/chat-ws"; })
Description: Constructs a new chat session and directly connects to it
Example:
var session = "programming" "My_Username" "password123" server: "wss://custom-server.com/chat-ws" ;
sendRaw(json: any)
Description: Sends a raw JSON packet
Example:
session;
sendMessage(message: string)
Description: Sends a chat message
Example:
session;
invite(user: string)
Description: Invites a user to a random channel
Example:
session;
session;
ping()
Description: Sends a ping packet. Can be used to check IP limit.
leave()
Description: Disconnects from the server, making this
unusable
HackChat.Session events
All HackChat events are the same as the HackChat.Session events with the exception that the session where it got emitted from is the first argument
.on("joining")
Description: Emitted when sending the join request.
Arguments: None
.on("left")
Description: Emitted when disconnected from WebSocket.
Arguments: None
.on("chat")
Description: Emitted when someone sends a regular message.
Arguments:
nick
(String)text
(String)time
(Number, Unix Time)isAdmin
(Boolean)trip
(String) - Hash from password
.on("info")
Description: Emitted when some unhandled info event passes through.
Arguments:
text
(String)time
(Number, Unix Time)
.on("infoRaw")
Description: Emitted when any info event occurs. Will also trigger if it gets handled.
Arguments:
text
(String)time
(Number, Unix Time)
.on("warn")
Description: Emitted when some unhandled warn event passes through.
Arguments:
text
(String)time
(Number, Unix Time)
.on("warnRaw")
Description: Emitted when any warn event occurs. Will also trigger if it gets handled.
Arguments:
text
(String)time
(Number, Unix Time)
.on("ratelimit")
Description: Emitted when server is sending IP ratelimit warning. Will cancel regular warn event.
Arguments:
time
(Number, Unix Time)
.on("banned")
Description: Emitted when admin is banning the user. Will cancel regular warn event.
Arguments:
time
(Number, Unix Time)
.on("nicknameInvalid")
Description: Emitted when nickname trying to join with is invalid ("!", "$", "?", etc.) Will cancel regular warn event.
Arguments:
time
(Number, Unix Time)
.on("nicknameTaken")
Description: Emitted when nickname trying to join with is already taken. Will cancel regular warn event.
Arguments:
time
(Number, Unix Time)
.on("invited")
Description: Emitted when WebSocket successfully invited someone. Will cancel regular info event.
Arguments:
nick
(String)channel
(String)time
(Number, Unix Time)
.on("invitation")
Description: Emitted when someone invited WebSocket. Will cancel regular info event.
Arguments:
nick
(String)channel
(String)time
(Number, Unix Time)
.on("onlineSet")
Description: Emitted when successfully joined. Will contain an array of users.
Arguments:
nicks
(String[])time
(Number, Unix Time)
.on("onlineAdd")
Description: Emitted when someone joins the channel.
Arguments:
nick
(String)time
(Number, Unix Time)
.on("onlineRemove")
Description: Emitted when someone leaves the channel.
Arguments:
nick
(String)time
(Number, Unix Time)
.on("error")
Description: Emitted when receiving invalid JSON or if WebSocket fails to send.
Arguments:
exception
(any)
