Micro SD Extension Cable
beagleboard-foundationBeagleBoard Foundation wrote 10/19/2017 at 17:46 • 2 min read • Like
 writes on the Tindie blog:
extension1-wb
Weirdly, one problem with memory now being so small is that these drives can be placed in areas that are difficult to access. Usually this means some sort of USB adapter (another amazing improvement over serial or parallel ports), but if you just want an actual SD extension cable in the form of a micro SD card, here it is! This device was conceived of when programming a BeagleBone Black, and could have lots of other applications.
extension2
micro SD extension cord designed by Tem Products:
I designed this little tool while compiling a software installation on BeagleBone Black. I needed to repetitively remove/inset the micro SD card. The BeagleBone was installed in a hard-to-reach area. So much time was wasted trying to inset the card with tweezers.
This simple tool plugs into the hard-to-reach socket, and provides a flexible extension.
Length: 3.5″
Like
James Newton wrote 02/09/2019 at 02:18 point
Dude... we need these for the Dexter HD robot. Any chance you can make 10 of them for us ASAP?
Jasmine Brackett wrote 11/16/2017 at 00:10 point
First batch sold out pretty quick. It's back in stock now https://www.tindie.com/products/TEMProducts/micro-sd-extension-cord/
oshpark wrote 11/17/2017 at 04:31 point
thanks for the link!
