How to Connect Cricut Explore Air 2 Bluetooth to Computer?
cricut-design-spacecricut design space wrote 09/02/2024 at 12:46 • 5 min read • Like
In this post, I will explain how to connect Cricut Explore Air 2 Bluetooth. Whether you are a Windows or Mac user, this blog will help you connect your machine and device easily.
When I got my crafting machine for the first time, I was a little overwhelmed, as I didn’t know how to connect it to my computer. But one of my friends, John, who is a professional crafter, helped me with this. Since then, I have been setting up my machine without anyone’s support. Now, I want to help you in the same way, as this is a beginner-friendly blog specially curated for novice crafters.
In this blog, I will explain how to connect your machine to the computer of your choice. Before that, I will also explain the system requirements for both Windows and Mac. Let’s start!
System Requirements for Connecting Cricut to Your Computer
Before you learn how to connect Cricut Explore Air 2 Bluetooth, you must review the system specs. This is very important before you set up your machine.
For Windows
For macOS
How to Connect Cricut Explore Air 2 Bluetooth to Windows?
I will show you how to establish a connection between your machine and Windows PC. Although the following steps can be used for another Cricut model, here I am specifically explaining it for the Explore model. Let’s take a look at the below steps:
  1. Ensure you have placed your machine at a distance of 10 to 15 feet from your computer.
  2. After that, open the Settings.
  1. To open settings, click on the Windows logo icon located in the taskbar and search for Settings app.
  2. On the settings window, head to the Devices option.
  1. Next, confirm whether the Bluetooth is on.
  2. Now, select Add Bluetooth or other device.
  1. By clicking on the above option, you will see the next pop-up screen.
  2. On the pop-up screen, select the Bluetooth option.
  3. Then, wait for a moment and see if your PC detects any nearby machine.
  4. After some time, you will see that your PC detects your machine and confirms that it is your machine model.
  5. If you found your model, select the machine from the given list of detected devices.
  6. Afterward, your machine is now connected to your Windows PC.
How to Connect Cricut Explore Air 2 Bluetooth to MacBook?
On a MacBook, you can connect the machine using Bluetooth wirelessly. After this connection, you can set up your machine with your Mac and start using it. Let’s have a look at the following steps to connect:
  1. Ensure the proper gap between your machine and computer.
  2. Then, turn these devices on.
  3. Once done, you will need to go to the Apple menu.
  4. After that, select the System Preferences.
  1. Next, you have to select your Bluetooth app from the System Preferences.
  1. Now, you need to turn on the Bluetooth.
  2. Afterward, wait for a moment and see if your Mac detects your machine.
  3. Once detected, you will need to tap the Pair button to connect it.
  4. Finally, your crafting machine is paired now.
Final Words
In this blog, I have explained how to connect Cricut Explore Air 2 Bluetooth on Windows PC and Mac. Following the above methods will help you connect your machine easily to your system via Bluetooth. Although I could connect my machine via a USB cable, I prefer a wireless connection. With a wireless connection, you don’t need to manage those tedious wires or cords.
FAQs
Question 1: Why is Cricut Explore Air 2 not connecting to Bluetooth?
Answer: There could be multiple reasons why your machine is not connecting to your Bluetooth. Below, I’ve mentioned the reasons:
  1. Check the distance that the machine is placed 10-15 feet away from the PC.
  2. Confirm the Bluetooth is turned on.
  3. Ensure the browser cache and cookies are cleared; remove them to fix the issue.
Question 2: Why is my Cricut Explore Air 2 not working?
Answer: If your machine is not working properly, then the reasons could be as follows:
  1. Check if the power button is solid red. If it is, it means there is a power issue.
  2. You can try plugging the machine into another wall outlet. In most cases, this will solve your problem.
Question 3: How can I reset my Cricut Bluetooth?
Answer: In order to reset the machine’s Bluetooth, you will need to walk through the following steps:
  1. First, open Settings.
  2. You need to go to Bluetooth on your Android device.
  3. Check if the Bluetooth is off.
  4. Turn it on and click on the gear icon located adjacent to your machine that shows up on the list.
  5. After that, click Forget
Visit: install cricut design space app
Source: https://cricutcreate.blogspot.com/2024/09/how-to-connect-cricut-explore-air-2.html
Like
