How to Install Cricut Design Space on Mac: A Stepwise Guide
cricut-design-spaceCricut Design Space wrote 09/03/2024 at 06:26 • 5 min read • Like
Do you want to use a Cricut machine on your Mac? If yes, then you must learn how to install Cricut Design Space on Mac. If you don’t know how to do it, don’t worry! In this post, I will guide you through downloading and installing the app on your computer. Apart from that, you will also learn the other important things that are necessary to use a crafting machine on your Mac. To learn the whole procedure, read the blog till the end.
Also, you need to do a few things to use your crafting machine. First, you should check if your device is compatible with Cricut. To work on the machine, you will have to connect it to your computer. Then, you must download the Design Space software on your computer. So, let’s start with the system requirements for using the app on your Mac.
System Requirements for Using Design Space on Mac
Before you install Cricut Design Space on Mac, you should check your computer’s compatibility with the app. If you try to download it on your device and your computer is not compatible, you will have trouble downloading the software, and even if you get it downloaded, you cannot use it properly. These are the specifications a Mac should have for your crafting machine.
Once you have checked your Mac’s system requirements and found that it is compatible with the machine, you should continue to download the software on your computer. To get it, you will have to perform the directions in the section below:
  1. To start the process of downloading, first open your computer and connect it to a Wi-Fi network.
  2. Then, open a browser on your Mac and visit cricut.com/setup. There, look for the Design Space, and when you see it, click on Download. But before that, don’t forget to tick the box to agree to the Terms of Use and Privacy Policy.
  3. When you click on Download, the dmg file will be saved in the Downloads folder of your computer. However, you can also find it on the browser’s download icon.
  4. Now that your file has been downloaded, you must go to it and open it by clicking on it twice.
  5. When you open the file, a new window with two icons will appear on your screen.
  6. Afterward, you should drag the Cricut icon into the Applications icon.
  7. Then, go to the Applications icon and open the app again.
  8. You will have a new window on the screen, and you have to click on Open.
  9. The app installation is complete on your computer. Now, you have to log in or sign up with your account.
How to Connect Cricut Machine to Mac?
Once you install Cricut Design Space on Mac, you should connect it to your machine. Here is the process of connecting your machine to your Mac operating system.
  1. First, add your machine to an electric outlet, and then press the power key on your machine.
  2. Once the machine is on, make sure the distance between the machine and your Mac is less than 10-15 feet.
  3. Then, find Bluetooth by going to System Preferences in your computer’s Apple menu.
  4. After that, turn on the Bluetooth on your device and wait until your machine pops up on the screen.
  5. Now, select the machine, and it will connect to your computer.
  6. To ensure the connection, you can visit the Cricut New Product Setup on the Design Space app.
Conclusion
Hopefully, you read the blog till the end, and now you sure know how to install Cricut Design Space on Mac. With the help of the post, you also learned other things that are important for setting up your machine and using it on your Mac computer. First, you read about your system requirements, which you must check. Then, you learn how to download the app on your device. Lastly, you saw the connection process of your Mac with your machine. Using all these methods, you can easily set up and use your machine to start your crafting projects.
FAQs
Is My Mac Compatible With Cricut Design Space?
To know the answer to the question, you must be sure about the operating system you are using. For your Mac, it has to be a macOS 11 or newer version. In that case, your computer will be compatible with Cricut. But you should check a few other things as well. For example, your Mac should have a Bluetooth or USB port, 2-3 Mbps internet speed, 1024 x 768 px screen resolution, 4 GB RAM, and 2 GB free disk space.
Why Is Cricut Software Running Slow on My Mac?
If the application on your computer is running slow and you are having trouble using Cricut, you should check a few things. First, make sure that your Mac is compatible with your machine and that it has all the features required to use the software. You should also make sure that you are using an updated version of the Design Space App. Once you check these things, your problem will be solved.
Is Cricut Design Space Available on Mac for Free?
Yes, it is available for free not only on Mac computers but also on other devices. If you want to use the app for free on your MacBook, you can download and install it on your computer. It will give you thousands of free designs, images, and fonts to use for your projects. You can also create your own design or upload an SVG file.
Source: How to Install Cricut Design Space on Mac
Like
