The ADXL335 Module is a compact and energy-efficient 3-axis accelerometer that provides signal conditioned voltage outputs. ADXL335 Module has a minimum full-scale range of ±3 g for accurately measuring acceleration.
This breakout board has the capability to measure both static gravity acceleration in tilt-sensing scenarios, as well as dynamic acceleration caused by movement, impact, or tremors. It is equipped with a built-in voltage regulator and operates seamlessly at 3.3V and 5V (3-5V).
An accelerometer is an electro-mechanical device capable of measuring both static and dynamic acceleration forces. This includes the constant force of gravity acting on your feet, as well as any movement or vibrations that may affect the device.
Systems such as FPV, RC, and Robots.
Navigation systems that utilize GPS technology
Acknowledging and recording the effects.
Devices used for gaming and virtual reality experiences
Features that are activated by movement.
Efficient energy conservation for portable devices.
Monitoring and compensating for vibrations
The detection of free-fall.
Detecting 6D orientation
The characteristics include:
- One feature on the board is a Low Dropout (LDO) Voltage Regulator.
- Can be connected to either a 3V3 or 5V Microcontroller.
- With an ultra-low power consumption rate of only 40uA in measurement mode and an impressive 0.1uA in standby at 2.5V, this device ensures efficiency without compromising on performance.
- This feature includes the ability to detect taps and double taps.
- A feature for detecting free-fall is included.
- The analog output has been successfully connected to the device and is now functioning properly.
- Incorporate an ultra low noise linear LDO voltage regulator.
- The device contains built-in onboard filters that effectively minimize noise from the motor and other high current electronics.
- All sensors on the I2C bus
- By using a soldered jumper, it is simple to choose two I2C addresses for the MPU6050.
- The LED indicating power.
- Incorporate a Logic level converter for I2C connectivity.
- Optimized for 5V logic
