I ordered a XY-SK120 buck-boost converter with digital controller with LCD screen from Aliexpress. With it I can dial up any desired voltage and use current limiting to forestall damage when first powering up projects. It has many other features. From the specs it's quite an impressive piece of electronics for its small size. Input can be 6-36 VDC and output 0-36 VDC at up to 6 A and it handles up to 120W.
I chose the cased version. It's more than just the bare converter board with banana sockets in an enclosure. At the back is a cooling fan and a power input panel that takes various sources, including terminal block, barrel socket, some kind of Molex socket, and even USB-3 PD input. A cursory inspection shows that diodes isolate the inputs from each other. These extras account for the higher price.
The fly in the ointment is poor documentation. It would be nice to know how to operate the UI without trial and error. Not even a slip of paper in the box. But a bit of hunting found an instruction manual online. From the modification date, less than 3 months ago, the firmware is still being improved, and in the future it might be possible to update it using the serial interface.
Normally one would use a SMPS or an old laptop power brick for the input. I decided to put to use an old school power supply board possibly from an LA30 Decwriter that the board for #Flashing LEDs from old printer electronics came from. In the board pictured below, only one set of bridge rectifiers and one large capacitor are in use. There are actually two independent power supplies on the board. The low voltage one supplies digital logic via a 5 V regulator, one of the large TO-3 cases. I won't be using that half. The high voltage one supplies the electromechanics. The capacitor is a whopping 10000 µF rated for 50 V so lots of margin. Nominal voltage level was probably around 30 V. A 24 VAC appliance transformer that I was given feeds the board.
For the enclosure I used an old Ryobi timer saved from e-waste. It seems to have been an appendage to unknown industrial equipment. The inside was gutted to fit the PS PCB.
That such a small controller can provide 6 A is a testament to how much the power density of electronics has increased over the years. (But some reviews mention that the cooling fan may be inadequate at high power levels.) The current is more than the old bulky linear power supply can supply. The fuse on the rectifier board is rated at 2.5 A. The transformer is rated at 1.5 A. (Although at lower output voltage, more current can be supplied, as the converter is switching mode.) Anyway this is enough for my needs for the near future.
Oops, I forgot to order 4 mm banana plug cables. Next round then. Can't buy everything in the shops all at once. 😉
Well that takes another tuit off my round tuit list.
Update 2025-08-25, replaced the feed PSU
Unfortunately a couple of weeks ago the converter went off in the middle of the night while powering a project.
Cut to the chase, I replaced the feed PSU with an old laptop brick capable of supplying 85 W @ 19 V so the last two pictures are no longer relevant. And now it's more efficient.
But this isn't newsworthy except for the steps I took to find the problem. It's an old school step-down transformer feeding a bridge rectifier followed by a whopping big electrolytic capacitor. The voltage on the secondary seemed normal at about 23 VAC. But after the rectifier the voltage under load was 2.5 VDC. No wonder the converter didn't work.
But what was the faulty part, the connections, the transformer, the rectifier, the capacitor, or the converter? I tried disconnecting components one at a time and found that removing the converter brought the voltage up to about 29 V. Damn, did I have a busted converter? Then I thought to monitor the voltage on the capacitor for a few seconds after powering up. The voltage rose gradually over seconds, not almost instantly. This meant that the transformer had a high impedance. Mostly likely a break in the winding that had enough conduction to charge the capacitor slowly. Oh well, one heavy transformer for the e-waste bin then.
Ken Yap
https://myosuploads3.banggood.com/products/20240730/20240730030057XY-SK60and120W.pdf is the manual, but no mention of the modbus register layout needed to actually use the thing. i've held off buying because i don't really want their display for extra money when i'd only control it from a ttl connection anyway and i can't do the ttl connection without the register layout that doesn't seem to be documented.
Thanks, that's the same one I found online, I should have provided a link to it. I don't need remote control so firmware is not an issue for me for the moment.
You need to buy the interface separately.
WiFi = XYWFPOW SiniLink ESP8265H16
RS-485 = XY-K485X
App = SiniLink (Android), then you can download the PC interface, or access directly using RS-485
This is hackaday, nobody wants to use their spyware apps here. We want direct access over the TTL link that the XYWFPOW SiniLink ESP8265H16 or XY-K485X use. ;-)
I broke down and bought one without documentation since there are docs for similar units and it probably uses derivative software. It'll be here in about a week and then we'll know.
