10127815-08LF Right-Angle PCB Connector: A Complete Guide
archibald007Archibald007 wrote 11/20/2024 at 08:02 • 5 min read • Like
What is 10127815-08LF?
The 10127815-08LF is a high-performance connector manufactured by Amphenol – a leader in the development of electronic interconnects. This model is part of the Amphenol RF series and is designed to provide reliable, high-quality connections in a variety of electronic systems, including telecommunications, data transmission, and industrial applications. With a right-angle configuration, it is optimized for space-constrained environments, delivering efficient signal transmission while maintaining a compact form factor.
This model is RoHS-compliant and features low-profile design characteristics that are ideal for high-density applications. The 10127815-08LF is designed to ensure superior signal integrity, with an easy-to-use interface that provides secure connections for a wide range of signal transmission needs. It's highly versatile and suitable for applications in radio frequency (RF) communications, data systems, and test equipment, among others. As a reliable electronic components distributor, Ersa Electronics will provide high-quality and original products for consumers.
 10127815-08LF image
Key Features of 10127815-08LF
The 10127815-08LF is a connector manufactured by Amphenol ICC (FCI), known for its robust design and various applications in electronic interconnect systems. Here are the key features of this connector:
Type: This connector is part of the Minitek® Pwr series, designed for power applications.
Contact Termination: It utilizes a crimp termination method, ensuring a secure and reliable connection.
Fastening Type: The connector features a latch lock fastening mechanism, which provides stability and prevents accidental disconnection.
Color: The housing color is natural, which is typical for many connectors.
Compliance: It is Glow Wire Compliant, meaning it meets specific safety standards regarding heat resistance and flammability.
Insulation Material: The connector is made from polyamide (PA66), specifically Nylon 6/6, which offers excellent thermal and mechanical properties.
Voltage Rating: It has a maximum voltage rating of 250V AC, suitable for various electrical applications.
Dielectric Withstanding Voltage: The connector can withstand up to 1500VAC, ensuring safety during operation.
Wire/Cable Gauge Compatibility: It supports a range of wire gauges, making it versatile for different wiring needs.
These features make the 10127815-08LF a reliable choice for power connection in various electronic devices and systems. If you need any electronic components, you can find on Ersa Electronics.
Advantages of Using 10127815-08LF
The 10127815-08LF connector offers several advantages that make it a preferred choice in various applications. Here are the key benefits:
High Current Rating: With a current rating of up to 9A per circuit, this connector is suitable for power applications, ensuring efficient energy transfer without overheating.
Versatile Applications: It supports multiple configurations, including wire-to-wire, wire-to-board, and wire-to-panel connections, making it adaptable for different electronic systems such as consumer electronics, medical devices, and industrial equipment.
Robust Design: The connector features a scoop-proof design and fully polarized housing, which prevents accidental mis-mating and enhances safety during operation. This ensures that terminals are well secured and protected from potential damage.
Durability: It is rated for 30 cycles of durability, allowing for repeated connections and disconnections without significant wear, which is ideal for applications requiring frequent maintenance or adjustments.
Temperature Resistance: The operating temperature range of -40°C to +105°C allows it to function reliably in diverse environmental conditions, making it suitable for both indoor and outdoor applications.
Flammability Compliance: The housing material is rated UL94V-0 for flammability, ensuring that it meets safety standards necessary for electronic components used in various industries.
Low Insertion Force: The connector design allows for low insertion force when installing crimped terminals, facilitating easier assembly without compromising the connection integrity.
Interchangeability: It is compatible with other connectors like the Molex Micro-Fit™, providing flexibility in design and ease of replacement in existing systems.
These advantages make the 10127815-08LF a reliable and efficient choice for engineers and designers looking for high-performance connectors in their projects.
10127815-08LF Applications
The 10127815-08LF connector is versatile and widely used in various applications due to its robust design and reliable performance. Here are the primary applications:
Consumer Electronics: Commonly used in devices such as smartphones, tablets, and laptops, where reliable power and signal connections are essential.
Sensing & Instrumentation: Employed in sensors and measurement devices that require stable connections for data transmission and power supply.
Medical Devices: Utilized in medical equipment where safety and reliability are critical, ensuring secure connections in devices like diagnostic machines and monitoring systems.
Lighting Systems: Integrated into LED lighting and other electrical lighting systems, facilitating efficient power distribution.
Communications & Networking: Used in networking equipment such as routers, switches, and communication devices, providing stable connections for data transfer.
Computers & Computer Peripherals: Found in various computer components, including motherboards and peripheral devices, ensuring effective power and data connectivity.
Industrial Applications: Suitable for industrial machinery and automation systems where durable and reliable connectors are necessary for operational efficiency.
These applications highlight the connector's adaptability across multiple sectors, making it a preferred choice for engineers and designers seeking dependable interconnect solutions.
Working Principle of 10127815-08LF
The 10127815-08LF connector operates based on a straightforward yet effective working principle that facilitates reliable electrical connections in various applications. Here’s an overview of its working mechanism:
Connector Design
Type: The 10127815-08LF is a female socket connector designed for use in wire-to-board, wire-to-wire, and wire-to-panel applications. It features a receptacle housing with 8 positions arranged in a straight orientation.
Pitch: It has a contact pitch of 4.2 mm (0.165 inches), which defines the spacing between the contacts and allows for efficient use of space in electronic assemblies.
Electrical Connection
Contact Mechanism: The connector utilizes crimp termination, where the contacts are crimped onto the wires (ranging from 28 AWG to 16 AWG). This method ensures a secure mechanical and electrical connection.
Latch Locking System: A built-in latch mechanism provides positive locking, which prevents accidental disconnection during operation. This feature is crucial for maintaining continuity in power and signal transmission.
Current and Voltage Ratings
The connector is rated for a maximum current of 9A per circuit and can handle voltages up to 250V AC, making it suitable for various power applications. The design ensures that it can safely conduct electrical current without overheating or failure.
Environmental Resistance
The materials used (such as nylon for the housing) provide durability and resistance to environmental factors. The operating temperature range of -40°C to +105°C allows the connector to function reliably in extreme conditions.
Safety Features
The connector is compliant with safety standards, including being UL94V-0 rated, which indicates good flammability resistance. Additionally, it has a dielectric withstanding voltage of 1500VAC, ensuring safety against electrical surges.
Applications
Due to its robust design and reliable performance, the 10127815-08LF is widely used in consumer electronics, medical devices, industrial equipment, and various other applications where secure and efficient electrical connections are critical.
In summary, the working principle of the 10127815-08LF connector revolves around its effective design for secure electrical connections, robust current handling capabilities, and compliance with safety standards, making it an ideal choice for many electronic applications.
Like
