Allwinner T507 Audio System: DMA Channel, Audio Hub Configuration and Test Guide
forlinx-embeddedforlinx embedded wrote 05/30/2025 at 05:51 • 9 min read • Like
This guide provides a concise overview of the audio system on the Allwinner T507 platform, covering the DMA transfer mechanism, Audio Hub configuration methods, and commonly used audio testing tools. It is intended to help developers quickly set up and validate audio functionality.
When a DMA channel sound card records or plays digital audio, it uses the DMA channel to transfer audio data between itself and RAM without CPU intervention to improve the data transfer rate and CPU utilization.
T507 Audio System
Audio codec, Audio Hub, DMIC, OWA(One Wire Audio)
Audio codec: Built-in module with digital-to-analog conversion to convert audio digital signals to analog signals.
Audio Hub: T507-specific module integrates basic audio input and output functions and special hardware mixing functions. The mixing function has three input terminals and 4 x I2S, which can complete the mixing of three channels of data. The mixed data is output through HDMI, I2S0, I2S2 and I2S3.
Audio Path Configuration
To view the current audio device node on the system:
root@forlinx:/# cat /proc/asound/cards 0 [audiocodec     ]: audiocodec - audiocodec				//codec corresponding card0                      audiocodec 1 [sndahub        ]: sndahub - sndahub						//audio_hub corresponding card1                      sndahub 2 [sndhdmi        ]: sndhdmi - sndhdmi						//hdmi corresponding card2                      sndhdmi 3 [sndwm89603001a ]: sndwm8960_3-001 - sndwm8960.3-001a	//8960 corresponding card3                      sndwm8960.3-001a                       root@forlinx:/proc/asound# cat devices  0: [ 0]   : control							//device 0 16: [ 0- 0]: digital audio playback 24: [ 0- 0]: digital audio capture 32: [ 1]   : control							//device 1 33:        : timer 48: [ 1- 0]: digital audio playback			//APBIF_TXDIF0	play hub_device 0 49: [ 1- 1]: digital audio playback			//APBIF_TXDIF1	play hub_device 1 50: [ 1- 2]: digital audio playback			//APBIF_TXDIF2	play hub_device 2 56: [ 1- 0]: digital audio capture				//APBIF0	play hub_device 0 57: [ 1- 1]: digital audio capture				//APBIF1	play hub_device 1 58: [ 1- 2]: digital audio capture				//APBIF2	play hub_device 2 64: [ 2]   : control							//device 2 80: [ 2- 0]: digital audio playback 96: [ 3]   : control							//device 3
112: [ 3- 0]: digital audio playback
120: [ 3- 0]: digital audio capture
Audio_hub Default Configuration
Default i2s3 configuration
root@forlinx:/# tinymix -D 1
Mixer name: 'sndahub'
Number of controls: 26
ctl     type    num     name                                     value
0       ENUM    1       ahub audio format Function               null
1       BOOL    1       I2S0IN Switch                            Off
2       BOOL    1       I2S0OUT Switch                           Off
3       BOOL    1       I2S1IN Switch                            Off
4       BOOL    1       I2S1OUT Switch                           On
5       BOOL    1       I2S2IN Switch                            Off
6       BOOL    1       I2S2OUT Switch                           Off
7       BOOL    1       I2S3IN Switch                            On
8       BOOL    1       I2S3OUT Switch                           On
9       BOOL    1       DAM0IN Switch                            Off
10      BOOL    1       DAM1IN Switch                            Off
11      BOOL    1       DAM0OUT Switch                           Off
12      BOOL    1       DAM1OUT Switch                           Off
13      ENUM    1       APBIF0 Src Select                        NONE
14      ENUM    1       APBIF1 Src Select                        I2S3_TXDIF
15      ENUM    1       APBIF2 Src Select                        NONE
16      ENUM    1       I2S0 Src Select                          NONE
17      ENUM    1       I2S1 Src Select                          APBIF_TXDIF0
18      ENUM    1       I2S2 Src Select                          NONE
19      ENUM    1       I2S3 Src Select                          APBIF_TXDIF1
20      ENUM    1       DAM0Chan0 Src Select                     NONE
21      ENUM    1       DAM0Chan1 Src Select                     NONE
22      ENUM    1       DAM0Chan2 Src Select                     NONE
23      ENUM    1       DAM1Chan0 Src Select                     NONE
24      ENUM    1       DAM1Chan1 Src Select                     NONE
25      ENUM    1       DAM1Chan2 Src Select                     NONE
I2s0 Recommended Configuration
tinymix -D 1 1 1					//Open input for i2s0
tinymix -D 1 2 1					//Open output for i2s0 tinymix -D 1 7 0					//Close i2s3 input
tinymix -D 1 8 0					//Close i2s3 output
tinymix -D 1 14 I2S0_TXDIF
tinymix -D 1 16 APBIF_TXDIF1
tinymix -D 1 19 NONE
I2s2 Recommended Configuration
tinymix -D 1 1 1					//Open input for i2s2
tinymix -D 1 6 1					//Open output for i2s0
tinymix -D 1 14 I2S2_TXDIF
tinymix -D 1 18 APBIF_TXDIF1
The configuration of audio channels will affect the use of test routines:
Before conducting the playback test, please insert the prepared 3.5mm headphones into the HeadPhone interface. To play sound through the speaker, insert the pin wires of the prepared speaker (SPK_RP and SPK_LN) into the P32 or P31 interface.
Introduction to Testing Tools
1. alsa - utils: These are standard ALSA tools that utilize the alsa - lib standard library. Commonly used tools include amixer, aplay, arecord, alsaconf, etc.
2. tinyalsa: It is a simplified version of alsa - lib. It provides basic interfaces for PCM and control, and the interfaces can be used as needed. Commonly used tools are tinymix, tinyplay, tinycap.
T507 Audio Test Tool
The alsa-utils standard ALSA tool uses the alsa-lib standard library. Commonly used are amixer, aplay, arecord, alsaconf
tinyalsa is a simplified version of alsa-lib. It provides the basic interfaces for PCM and control, which can be used on demand. Commonly used tools are tinymix, tinyplay, tinycap1
1. codec (LINEOUT)
only DAC, no ADC. Therefore, it can only play, not record, and audio _ hub is not used.Play commands use aplay or tinyplay
aplay -Dhw:0,0 mic.wav
2. For the 8960 (external audio chip), its I2S signal passes through the audio_hub, which is a module unique to Allwinner. Audio recording using this.
Audio_hub (with the 8960):
root@forlinx:tinycap_ahub mic.wav -aD 1 -ad 1 -D 3 -d 0 -t 30 -b 16 -c 2 -p 1024
Usage: tinycap_ahub file.wav [-aD ahub card] [-ad ahub device] [-D card] [-d device][-c channels] [-r rate] [-b bits] [-p period_size] [-n n_periods] [-t seconds]
Audio_hub play (8960):
root@forlinx:tinyplay_ahub mic.wav -aD 1 -ad 1 -D 3
Usage: tinyplay_ahub file.wav [-aD ahub card] [-ad ahub device] [-D card] [-d device] [-p period_size] [-n n_periods]
Like
