Common Interface Problems and Troubleshooting Ideas of Forlinx Embedded AM62x Development Board (Phase 1)
forlinx-embeddedforlinx embedded wrote 06/13/2025 at 07:22 • 4 min read • Like
AM62x processor, as a new generation of high-performance and low-power processor, has been widely used in industrial control, human-computer interaction, edge computation and other fields. OK62xx-C development board based on AM62x processor provides abundant hardware interface resources for developers. This article will provide systematic troubleshooting ideas and solutions for various interface problems that may be encountered in the development process to help developers quickly locate and solve problems.
General Troubleshooting
In the process of hardware debugging, the systematic troubleshooting method can significantly improve the efficiency. The following is the general troubleshooting process:
Chip consistency verification:
First, make sure that the functional chip used is exactly the same as the reference design schematic. If the chip model is different, driver migration may be required, including modifying the device tree configuration and driver.
1. Basic signal checking:
For modules that fail feature verification, check in order:
2. Cross Test:
By replacing either the System on Module (SoM) or the carrier board, quickly identify the source of the problem.
3. Signal integrity check:
4. Welding quality inspection:
5. Pin Multiplexing Checking:
Refer to the AM62x Technical Reference Manual to confirm whether the function multiplexing configuration of the used pins is correct. Pay special attention to the default functions of the pins related to startup.
Troubleshooting of System Failure to Start
Follow the steps below to troubleshoot the issue of system failure to start:
1. Key signal inspection:
2. Start Configuration Check:
3. I2C bus conflict troubleshooting:
4. Cross Test:
Replace the SoM or carrier board and confirm if it is an isolated issue.
Troubleshooting of I2C Interface Issues
Common problems and solutions of I2C bus:
1. Basic configuration check:
2. Signal quality analysis:
3. Impedance matching adjustment:
If the rising edge of the waveform is slow, the pull-up resistance value can be reduced;
If the low level is too high, the pull-up resistor value can be increased.
4. Diagnostic tool usage:
Use the I2Ctool tool to check if any devices are mounted on the bus:
i2cdetect-l//Check how many groups of I2C are on the system
i2cdetect-r-y2//Detect mounted devices on the I2C second set of buses
Troubleshooting of SPI Interface Issues
Key points for troubleshooting SPI communication faults:
1. Confirmation of hardware connections:
2. Verification of mode configuration:
3. Signal measurement:
Troubleshooting of USB Interface Issues
Common problems with USB interfaces (2.0/4G/5G):
1. Power supply check:
2. Confirmation of signal connections:
Confirm that an AC coupling capacitor is connected in series with the USB transmission signal.
3. Special notes for USB:
Generally, an AC coupling capacitor has already been added to the transmission signal of the USB device end, so the receiving end does not need to add another coupling capacitor;
Check of level configuration:
Troubleshooting of SDIO Issues
1. Optimization of signal integrity:
2. Optimization of signal integrity:
Confirm that the SDIO bus has been subjected to equal-length processing.
3. Pull-up resistor configuration:
The above are the common problem types and troubleshooting ideas during the development process of the OK62xx-C development board. This article first introduces six major types of problems, including general ideas, non-startup problems, I2C interface problems, SPI interface problems, USB problems, and SDIO problems. Subsequently, problems with interfaces such as LVDS, PCIe, UART, and CAN and their solution ideas will also be introduced. We hope that you will continue to pay attention.
Like
