SP2301 Linux EVB: Enabling Dual-Port Ethernet for Industrial IoT
securepiSecurePi wrote 06/29/2025 at 07:46 • 3 min read • Like
Introduction
The SP2301 Linux EVB is a high-integration embedded Linux development board designed by WIZnet for industrial IoT and edge computing applications. Powered by a Cortex-A5 core-based SP2301 industrial-grade module, this EVB provides a feature-rich platform for robust and scalable industrial solutions.
Its design ensures that developers can easily implement reliable communication and automation systems, with built-in support for dual-port Ethernet through WIZnet's W5100S-io or W5500-io modules.
Key Features at a Glance
Detailed Specifications
Power
Ethernet
USB
Indicators
Cellular Communication
WiFi / Bluetooth
Expansion Interfaces
Dual-Port Ethernet: Reliable Separation of Control and Data
The unique dual-port design of the SP2301 Linux EVB separates the control plane and data plane physically:
This design improves system stability, security, and communication integrity — critical in industrial applications where control and data flows must not interfere with each other.
Industrial-Grade Reliability
The SP2301 Linux EVB is built for harsh conditions:
These features ensure the board can be deployed confidently in factory automation, smart grid, transportation, and other demanding environments.
Conclusion
With its comprehensive connectivity, flexible expansion, and dual-port Ethernet capability via the W5100S-io / W5500-io, the SP2301 Linux EVB is a powerful solution for developers creating next-generation industrial IoT devices and edge gateways. Its modular design accelerates prototyping, testing, and scaling to mass production, while its industrial-grade reliability ensures long-term, stable operation in critical applications.
Like
