⚡️When a MOSFET Meets Its Limit: What Really Happens During Voltage Spikes at High Temperature
mosfetMOSFET wrote 10/09/2025 at 02:08 • 3 min read • Like
Project type: Failure analysis / power electronics insight
Tags: #MOSFET #PowerElectronics #VoltageSpike #ThermalDesign #HardwareFail
🧩 The Day a “600V” MOSFET Failed Below 500V
You know that feeling when your prototype is finally running smoothly — until something pops?
That’s exactly what happened to our high-voltage motor control board.
It had passed every bench test, survived thermal cycling, and handled all loads… until the internal temperature hit 85 °C.
Then came the “click.”
Followed by silence and a faint smell of burned epoxy.
Post-mortem?
A 600 V MOSFET, split clean in half — and the voltage log showed only 480 V.
🔍 Myth Busted: High Temperature ≠ High Spike Margin
It’s easy to assume that higher temperature gives you more tolerance — after all, the datasheet says breakdown voltage increases slightly with temperature.
But that’s a static condition. Real circuits are never static.
In fast switching environments, parasitic inductances, gate ringing, and layout geometry dominate.
Those 10 ns overshoots don’t care what your nominal V<sub>DS</sub> is.
And once the MOSFET’s avalanche region absorbs too much localized energy, it’s game over — even if you never reach the official breakdown voltage.
⚙️ The Deep Dive: Where Spike Margin Actually Comes From
Spike margin isn’t a single parameter. It’s a cocktail of design factors:
On paper, two MOSFETs may look identical. On the scope, they behave like completely different species.
🔥 The Test That Changed Our Design Philosophy
We instrumented the next prototype with a high-bandwidth probe across drain-source.
Result:
Every turn-off event showed a transient +80 V spike, lasting 50 ns — enough to push local avalanche current through the die corners.
The solution wasn’t just a “better MOSFET.”
We redesigned the gate driver, shortened return loops, added an RC snubber, and verified avalanche energy under load.
That board hasn’t failed once since.
💡 Lessons Learned (So You Don’t Have to Burn Your Own Board)
  1. Design for margin, not miracles. Keep switching peaks < 80% of rated V<sub>DS</sub>.
  2. Layout is your first line of defense. Stray inductance kills faster than voltage.
  3. Use clamps or snubbers to tame energy — don’t let silicon absorb it all.
  4. Validate under stress. If you haven’t scoped it at full current and full temperature, you haven’t really tested it.
  5. Choose MOSFETs with robust avalanche energy specs, not just pretty voltage numbers.
⚔️ Key Takeaway
High voltage doesn’t guarantee safety.
High temperature doesn’t buy you margin.
Only engineering discipline keeps your MOSFET alive.
If your design depends on luck, it’s already a failure — it just hasn’t burned yet.
📊 Resources / Further Reading
💬 Discussion Prompt
What’s the worst transient-related failure you’ve ever debugged?
Did layout, switching speed, or bad luck take the blame?
Drop your scope horror stories below — we’ve all been there.
🔖 Tags for discoverability
#MOSFET #VoltageSpike #PowerElectronics #ThermalDesign #CircuitDesign #HardwareFail #PCBLayout #Reliability #Semiconductors #SwitchingLoss #ElectronicsEngineering #AvanlancheEnergy #DIYPowerDesign
Like
