Have you ever been in the middle of a DIY project when your Cricut Explore Air 2 suddenly stops working? Don’t worry – it happens to many Cricut users. Sometimes, a quick restart is all your machine needs to get back to normal. Restarting helps fix small glitches, connection issues, or software errors that can slow down your work. Here, I am going to walk you through when and how to restart your Cricut machine the right way. Whether it is a simple restart or a hard reset, these easy steps will help you get your machine running again so you can go back to creating your favorite designs without any stress.
When Should You Restart Your Cricut Explore Air 2?
You should restart your Cricut machine when it stops working properly or doesn’t respond as expected. Restarting helps fix small issues and refreshes the system so it can work smoothly again.
- During a cut: If your project freezes in the middle of cutting, then press the “Stop” button. If the light is still on, turn off the machine and turn it back on to reset it.
- After updates: Once you install a Cricut Design Space or firmware update, restart the machine to make sure the new changes work properly.
- For minor glitches: If your machine starts acting strangely or doesn’t follow your commands, then a restart can help clear temporary bugs.
- To clear the buffer: If you cancel a DIY project, then restarting clears leftover commands so your next design runs without problems.
- After connection loss: If your Cricut machine loses connection to your device, then restarting can help reconnect it easily.
Steps to Restart Cricut Explore Air 2
Restarting your Cricut Explore Machine is an easy process that helps resolve small issues and refresh your machine for smooth performance. Perform the steps in the section below to do it the right way:
Step 1: Press the power button to turn off your crafting machine. Make sure all the lights on the machine are off.
Step 2: After that, unplug the power cord from the machine and the wall outlet.
Step 3: Wait for about 1 minute. This short break allows the machine to reset completely.
Step 4: Next, connect the power cord to the wall socket and then to your machine.
Step 5: Now, you have to press the power button again to turn it back on.
Once your Cricut Explore machine restarts, you can try running a simple cut test to confirm that everything is working correctly.
Steps to Restart Cricut Explore Air 2 via Cricut Design Space
You can also restart your Cricut Explore Air 2 through the Cricut Design Space app if your machine is connected to a desktop or mobile phone. This method is very easy and helps fix software-related issues or connection errors. Follow these easy steps:
Step 1: First of all, you will need to open the ‘Cricut Design Space app‘ on your computer or phone.
Step 2: In the top-left corner, click on the Menu icon and go to Account or Settings.
Step 3: From the menu, select Machine and choose your Cricut model from the list.
Step 4: Click on Disconnect or Forget Device to remove the connection temporarily.
Step 5: After that, close the Cricut Design Space Software completely and then wait for a few seconds.
Step 6: Now, reopen Cricut Design Space, go to Connect Machine, and follow the prompts to reconnect your machine.
Once reconnected, your Cricut cutting machine will automatically restart through the app, which helps clear connection glitches or command issues.
When to Try a Hard Restart for Cricut Explore Air 2
You should try a hard restart for your Cricut Explore Air 2 when it stops working properly or doesn’t respond like it normally does. A hard restart can help fix common issues such as freezing, slow performance, connection problems, or software glitches. It’s like giving your machine a fresh start to clear any temporary errors.
You may need to try a ‘hard restart‘ in the following situations:
- When the machine freezes or becomes unresponsive: If your machine stops mid-cut or the lights stay stuck, then a hard restart can help reset it.
- When you face connection problems: If your machine isn’t connecting to the Cricut Design Space app or Bluetooth, then restarting can refresh the connection.
- After a failed firmware update: Sometimes updates don’t install correctly, causing issues that can be fixed with a hard restart.
- When cutting performance drops: If your machine cuts unevenly or the carriage moves strangely, then restarting can solve these problems.
Doing a hard restart won’t harm your Cricut machine – it clears minor errors and helps the machine start fresh. If the issue continues even after a hard restart, then it may need further troubleshooting or technical support.
Frequently Asked Questions (FAQs)
Why Is My Cricut Machine Not Cutting Properly?
How Do I Force Reload My Cricut Explore Air 2?
Learn how to force reload your machine, you can try a few simple steps based on the problem you are facing. The first option is to do a quick power cycle: turn off your machine, remove the plug from the wall outlet, wait about 30 seconds, and plug it back in. If the issue continues, then perform a manual reset by pressing the main power button for a few seconds until the machine restarts. Another way is to refresh the Cricut Design Space software on your computer – close the app, reopen it, and reconnect your machine. This will fix loading or syncing issues between your machine and the app.
How to Setup Cricut Explore Air 2 User Account?
Follow these steps to create a Cricut user account:
- Turn on the Cricut Machine.
- How to Connect the Cricut Machine to the USB cord or pair it using Bluetooth.
- Open your browser and visit Cricut.com/setup.
- Download and install the Cricut Design Space for your device.
- Perform the steps shown on your screen to Sign In or create your new user account.
- After that, setup your Cricut Machine.
How to Register Cricut Explore Air 2 on iOS/Android?
Below are the steps to register your Cricut Machine on a mobile device:
- Plug all the machine cables into the power outlet.
- Turn on Bluetooth on your phone and pair it with your Cricut Machine.
- Download the Cricut Design Space Software Application.
- After installation, Sign In or create a user ID.
- Next, click on the menu and select the option: Cricut Machine Setup.
- Select your Cricut machine model and follow the on-screen steps to finish the Cricut Explore Air 2 Setup.
How to Connect Cricut Explore Air 2 to Computer?
Follow the steps simplified below to connect your machine to your computer wirelessly:
- Turn on the machine and place it within 10 to 15 feet of the computer.
- Go to your Start menu.
- Navigate to Settings and open the Devices option.
Visit: cricut.com/setup
Source: https://mycricut-design-app.com/how-to-restart-cricut-explore-air-2-easy-guide/
williamwilsond32
