Daily01 Adjustment Ongoing
zitong-zhangZitong Zhang wrote 06/30/2026 at 07:35 • 1 min read • Like
Title: Don’t Let JTAG Hold You Back – Extend It with FPC!
Debugging servo motors is tricky enough without fighting cramped enclosures. Why wrestle with bulky debuggers when you can design a simple PCB that routes the JTAG interface out via a flexible FPC flat cable?
That’s exactly what we did. A tiny adapter board, a low‑profile FPC ribbon, and suddenly the debug port is right where you need it – no more awkward angles, no more stress on connectors. Signal integrity stays solid, and you can even hot‑plug with care.
The result? Faster iteration, cleaner setups, and happier engineers. Whether you’re tuning current loops or checking encoder feedback, this little hack saves hours.
Try it on your next servo drive – and keep your JTAG within arm’s reach
Like
