Sketch for generating test pulses for the power meter
gerard-te-meermanGerard te Meerman wrote 11/30/2017 at 22:29 • 1 min read • Like
//Sketch to generate timing pulses to test the power meter (an attiny85 is used, but any arduino will do the job)
 program to simulate the signal as generated from aa speedometer pickup by an arduino duemillenova
 it will be fed into another arduino that contains the power measuring algorithm
const int speedpin = 2;
void setup () {
  pinMode(speedpin,OUTPUT);
  digitalWrite(speedpin, HIGH);
void loop()
{   for (int i=1;i < 40;i++)
    digitalWrite(speedpin, LOW);
    delay(1);
    digitalWrite(speedpin,HIGH);
    delay(400);
  for (int i=1;i < 10;i++)
    delay(5);
    delay(400+i*10);
Like
