eBay Watt Meter review
frank-bussFrank Buss wrote 02/12/2018 at 22:40 • 2 min read • Like
I bought this watt meter from eBay. The case is a nice extruded aluminium case, but it is unusable for low currents. For example it shows 30 mA for a 100 mA load, tested with a passive resistor:
And still about 28% error for 1 A, tested with a passive resistor as well:
I guess for higher currents it gets better.
Internally it uses a shunt in the ground path, which is called low-side current measurement. This might be a problem if you have other things connected to ground to the device you are measuring:
It works down to about 4.7 V. But it should be possible to desolder the red wires from the board and solder a wire for an external power supply to the PCB.
The display is soldered to the board, so I can't see details of the circuit:
Conclusion: if you want to measure high currents above 1 A and don't care about accuracy, you can use this. Otherwise don't buy it.
Like
