Unknown Error code?
ActualDragon wrote 04/12/2018 at 23:18 • 0 pointsI never check my arduino.cc account, and so I forgot my password. I'm usually on here, so i'll lay some error code here and if anyone can make sense of it, that would be great. On my project #12 Servo Hexapod , i'm 90% sure it's my mega that's screwing me over, so I had an idea and made a cheap shield for my name brand arduino (the mega is a clone). It can only control 6 servos, but I can still experiment with them fine. It's not that that's giving me problems either, because it still dosen't work without it. When I finally decided to upload the code, it flashed me this:
Arduino: 1.8.5 (Mac OS X), Board: "Arduino/Genuino Uno"
/Users/svteacher/Downloads/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Users/svteacher/Downloads/Arduino.app/Contents/Java/hardware -hardware /Users/svteacher/Library/Arduino15/packages -tools /Users/svteacher/Downloads/Arduino.app/Contents/Java/tools-builder -tools /Users/svteacher/Downloads/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/svteacher/Library/Arduino15/packages -built-in-libraries /Users/svteacher/Downloads/Arduino.app/Contents/Java/libraries -libraries /Users/svteacher/Documents/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10805 -build-path /var/folders/_h/cw2_jv2j0kb8m4shtlxb48900000gq/T/arduino_build_154053 -warnings=none -build-cache /var/folders/_h/cw2_jv2j0kb8m4shtlxb48900000gq/T/arduino_cache_844144 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/Users/svteacher/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=/Users/svteacher/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=/Users/svteacher/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.1.1 -verbose /Users/svteacher/Documents/Arduino/hexapod_one_leg/hexapod_one_leg.ino
/Users/svteacher/Downloads/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Users/svteacher/Downloads/Arduino.app/Contents/Java/hardware -hardware /Users/svteacher/Library/Arduino15/packages -tools /Users/svteacher/Downloads/Arduino.app/Contents/Java/tools-builder -tools /Users/svteacher/Downloads/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/svteacher/Library/Arduino15/packages -built-in-libraries /Users/svteacher/Downloads/Arduino.app/Contents/Java/libraries -libraries /Users/svteacher/Documents/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10805 -build-path /var/folders/_h/cw2_jv2j0kb8m4shtlxb48900000gq/T/arduino_build_154053 -warnings=none -build-cache /var/folders/_h/cw2_jv2j0kb8m4shtlxb48900000gq/T/arduino_cache_844144 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/Users/svteacher/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=/Users/svteacher/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=/Users/svteacher/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.1.1 -verbose /Users/svteacher/Documents/Arduino/hexapod_one_leg/hexapod_one_leg.ino
Using board 'uno' from platform in folder: /Users/svteacher/Library/Arduino15/packages/arduino/hardware/avr/1.6.21
Using core 'arduino' from platform in folder: /Users/svteacher/Library/Arduino15/packages/arduino/hardware/avr/1.6.21
Detecting libraries used...
"/Users/svteacher/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Users/svteacher/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/cores/arduino" "-I/Users/svteacher/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/variants/standard" "/var/folders/_h/cw2_jv2j0kb8m4shtlxb48900000gq/T/arduino_build_154053/sketch/hexapod_one_leg.ino.cpp" -o "/dev/null"
Generating function prototypes...
"/Users/svteacher/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Users/svteacher/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/cores/arduino" "-I/Users/svteacher/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/variants/standard" "/var/folders/_h/cw2_jv2j0kb8m4shtlxb48900000gq/T/arduino_build_154053/sketch/hexapod_one_leg.ino.cpp" -o "/var/folders/_h/cw2_jv2j0kb8m4shtlxb48900000gq/T/arduino_build_154053/preproc/ctags_target_for_gcc_minus_e.cpp"
fork/exec /Users/svteacher/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++: no such file or directory
Error compiling for board Arduino/Genuino Uno.
Oh man, I don't even know where to start. :p
I don't think it will help, mainly because i haven't been able to test it (see above XD), but here's the code:
#include <Servo>
Servo topservo;
Servo bottomservo;
void setup() {
topservo.attach(8);
bottomservo.attach(9);
void loop() {
bottomservo.write(0);
topservo.write(50);
delay(1000);
topservo.write(0);
bottomservo.write(110);
delay(1000);
Try
#include <Servo.h>
AlanX
