Micropower Micro Logger
oshparkoshpark wrote 10/11/2018 at 16:58 • • 1 min read • Like
A set-and-forget I2C/digital datalogger from Jan on Hackaday.io
micropower micrologger [mPmL]
This is a logical development from my first and second logger projects. The idea is simple: The logger needs to be small enough to fit inside small spaces, e.g. a bee hive.
With the press off a button it starts/stops logging. The casing can be as simple as shrink tubing!
Like
Jan wrote 10/11/2018 at 22:03 • point
Thanks a lot for sharing/hosting my logger project, much appreciated. A even smaller version is nearly finished. Half the size but an estimated runtime of *insert battery shelf life here* :)
Will order the PCBs from you of course.
Cheers, Jan
