Electronic standard parts : Power Supplies
christoph-tackChristoph Tack wrote 03/07/2019 at 19:22 • 2 min read • Like
DC DC Converters Board Mount
DeviceSpecificationsSources
Buck converter module
Input voltage : 4.5V - 28V
Output voltage : 0.8 - 20V
Output current : 3A
Efficiency : 92%
Switching frequency : 1MHz - 1.5MHz
Operating temperature : -20°C - +85°C
Size : 22 x 17 x 4 mm
WAVGAT XM1584
Driver IC : MP1584
Boost converter module
Input voltage : 2-24V
Output voltage : 2-28V
Output current & Efficiency
Switching frequency : 1.2MHz
Remark: high components, easily broken
Size : 23 x 17 mm
HWA YEH SX1308
Driver IC : SX1308,
pin compatible to MPS MP3221
Boost converter moduleInput voltage : 2-24V
VIN=4.2V, VOUT=5V, Imax=0.5A (η=82%)
VIN=3.7V, VOUT=5V, Imax=0.4A (η=82%) VIN=3.0V,VOUT=5V, Imax=0.3A (η=79%)
Size: 30 x 17 x 14 mm
AliEpress 32851687094
Driver IC : MT3608
Boost converter IC
Consider using a boost LED driver.  They are cheap, but might not have true output disconnect.
Input voltage : 0.8 to 5.5V
Output voltage : 2 to 5.5V
Output current : 350mA
EN = active high
* True output disconnect (1µA leakage):
MCP1640 & MCP1640B
not MCP1640C or D
* MP3120 compatible to AAT1217
Buck boost converter module
Input voltage : 1.5-6.5V
Output voltage : 3V3
Output current :
* 1.5VIN -> 150mA
* 3.7VIN -> TBD
* 6.5VIN -> >3.0A
Evaluation
AliExpress 32757272432
Driver IC : MicrOne ME2149
Input voltage : 3-15V
Output current : ?
AliExpress 32892547111
3V3 LDO
* RT9080 (600mA, 2µA Iq)
* Richtek RT9073N-33GB (3µA Iq, 0.6V dropout, Imax=250mA)
* S-1313C33-M5T1U3 (200mA, 1.35µA Iq)
* NCP718ASN330T1G (300mA, 4µA Iq)
* HT7833 (LCSC C164106, SOT23-5)
Alternative :
Holtek HT7333 (250mA, SOT89-3, Iq=5µA, 0.3V dropout)
Load switches
If the MCP1640 consumes too much current to your mind (1000nA), then you can add a load switch.  The TCK106AF,LF, TCK108AF,LF and TPS22917DBVR are excellent low power switches.
Like
