How to change Xfinity Wi-Fi Password ?
vikuhelpvikuhelp wrote 07/02/2019 at 06:43 • 2 min read • Like
Comcast Modem/Router is the one of the leading and renowned Router, used by billions number of users globally. But, sometimes it has been viewed that users can't change Xfinity wifi password without expert’s guidance. The reason behind it is, that they not aware of the procedure of technical terms.
Anyway, change Xfinity wifi password is not a difficult as its view at user point. The users can easily do with their system or mobile devices. The users will need to follow the below given some procedure that has been suggested to the Comcast technical support team to speedily change Wi-Fi password of Xfinity router.
Simple Steps to change Xfinity wifi password on iPhone
Here are defined very simple steps to change the password for your Xfinity WiFi account or wireless router using a computer or iPhone.
  1. Open Xfinity My Account on your phone or tablet. If you are not already signed in to your account, sign in now.
  2. Open your Internet settings by tapping the Internet at the bottom of the screen.
  3. Then tap your wireless modem or router. It’s located under the ″Devices″ header.
  4. Tap Change WiFi settings, which is the first option in the menu.
  5. Next, type the new password into the second blank. Make sure the password should be capita, lowercase letters, and are case-sensitive.
  6. Then click on “Save” button. It’s located at the bottom side of the screen with the “blue” button. The new password is now saved.
  7. Now you’ll see a message that says the gateway is being updated and that the process may take a few minutes.
  8. Tap the “Done” button.
  9. Then wait a few moments while the process complete. Then reconnect to the Wi-Fi network. Upon reconnecting, you’ll have to enter the new Wi-Fi password.
  10. Now you can connect WIFI to your computers, or phones, with using the new password.
Connect with Proficient Experts To Fix the Issue:-
In case, if you have any issue to follow the above steps, then dial the Comcast helpline number now. The customer service team is always ready for assistance. The proficient experts will give reliable approaches and correct solutions to Xfinity Wi-Fi queries within a few minutes. Hence, connect with dedicated technicians now for more help.
source: http://www.vikuhelp.com/blog/change-xfinity-wifi-password
Like
