eBox 3300/3310
craig-hissettCraig Hissett wrote 07/19/2019 at 21:14 • 2 min read • Like
I'm off on holiday for a week in a few hours, but when I get back I'm going to be playing with these:
One was given to me without a power supply by a friend of mine, and it took a few hours disassembly and googling to find out what it actually was; the ebox 3310. It had been running machinery software in a factory. Perfect for a lightweight Linux and running some python applications.
While looking for the wierd 3 pin connector it uses for power I stumbled across a 3300 on eBay, new, going for £15. I had to buy it ha ha!
Now it is here , it turns out to be a -H model with suppprts a 2.5 inch drive. Ideal!
I was going to look into perhaps sticking a Pi in my son's room and adding some basic automation stuff, but I'm tempted to use one of these.
Like
Ken Yap wrote 07/19/2019 at 23:53 point
My first thought on looking at the picture was: Intel NUC lookalike. However unlike the NUC, the RAM is onboard and limited to 512MB, which means you can only put a lightweight Linux distro on it. Still at £15 can't complain. If you are thinking along the lines of a RPi workalike, then perhaps the Raspberry Pi desktop distro might suit you: https://www.raspberrypi.org/downloads/raspberry-pi-desktop/
It has the advantage of having similar libraries to the RPi and Arduino, like WiringPi.
Craig Hissett wrote 07/20/2019 at 02:10 point
You've read my mind matey :)
I've used the Pi x86 software on a few really old laptops and it's worked great, so was going to look at using this first. I'd be using these for very lightweight tasks and in a completely headless capacity so it should be fine.
For the bedroom automation project I'm tempted to pair the 3310 with am Arduino Mega and communicate using one of the rs-232 ports.
Ken Yap wrote 07/20/2019 at 02:14 point
Or if you just need a heap of GPIO ports get one of those USB to GPIO adaptors. I've written about them in a previous comment to another project. I don't know if there's an easy way to search for all my posts on HAD.
Hopefully the Buster edition of Pi desktop will be out when you get back.
Craig Hissett wrote 07/20/2019 at 02:25 point
that's a great shout on the gpio adaptor matey. In fact I am sure I have two Ryantek usb-gpio boards I could use :)
