HPS FIFO Communication on Cyclone V Altera SoC
muhammad-atifMuhammad Atif wrote 09/02/2019 at 10:49 • 2 min read • Like
Hi,
I am trying to communicate HPS and FIFO on altera cyclone V SoC. I am able to write data but I am not able to read back the data. Anyone please help where I am wrong
#include <stdio.h>
#include <unistd.h>
#include <stdlib.h>
#include <stdint.h>
#include <fcntl.h>
#include <sys/mman.h>
#include <sys/types.h>
#include <sys/stat.h>
#include "C:\altera\15.1\embedded\ip\altera\hps\altera_hps\hwlib\include\hwlib.h"
#include "C:\altera\15.1\embedded\ip\altera\hps\altera_hps\hwlib\include\soc_cv_av\socal\socal.h"
#include "C:\altera\15.1\embedded\ip\altera\hps\altera_hps\hwlib\include\soc_cv_av\socal\hps.h"
#include "C:\altera\15.1\embedded\ip\altera\hps\altera_hps\hwlib\include\soc_cv_av\socal\alt_gpio.h"
#include "D:\TestDesigns\customfifoloopback1\hps_0.h"
//fifo status pointers
//#define FIFO_FULL		  ((*(FIFO_write_status_ptr+1))& 1 )
//#define FIFO_EMPTY	  ((*(FIFO_read_ptr+1))& 2 )
//Main bus addresses
#define FIFO_BASE            0xC0000000
#define FIFO_SPAN            0x00001000
//LW Addresses
#define REG_BASE 0xFF200000
#define REG_SPAN 0x00200000
//initializing the pointers
void* virtual_base;
void* h2f_virtual_base;
volatile unsigned int * FIFO_write_status_ptr= NULL;
volatile unsigned int * FIFO_read_status_ptr = NULL ;
volatile unsigned int * FIFO_write_ptr = NULL ;
volatile unsigned int * FIFO_read_ptr = NULL ;
unsigned int value;
int data[7];
int i;
//int FIFO_FULL;
//int FIFO_EMPTY;
//main functions
int main ()
int fd = EXIT_FAILURE;
fd=open("/dev/mem",(O_RDWR|O_SYNC));
if (fd < 0) {
		perror("open");
		exit(EXIT_FAILURE);
printf("fd is ok\n");
//accessing the virtual addresses of the fifo pointers
virtual_base=mmap(NULL,REG_SPAN,(PROT_READ|PROT_WRITE),MAP_SHARED,fd,REG_BASE);
h2f_virtual_base=mmap(NULL,REG_SPAN,(PROT_READ|PROT_WRITE),MAP_SHARED,fd,FIFO_BASE);
printf("virtual base pointer to open device memory file is ok\n");
FIFO_write_status_ptr = (unsigned int *)(virtual_base+FIFO_0_IN_CSR_BASE);
FIFO_read_status_ptr = (unsigned int *)(virtual_base+FIFO_0_OUT_CSR_BASE);
FIFO_write_ptr=(unsigned int *)(h2f_virtual_base+FIFO_0_IN_BASE);
FIFO_read_ptr= (unsigned int *)(h2f_virtual_base+FIFO_0_OUT_BASE);
printf("fifo pointers are ok\n");
//entering data into the fifo
for(i=0;i<8;i++)
	data[i]=i+1;
	*FIFO_write_ptr=data[i];
	printf("////////////////////////////\n");
	printf("you entered the value %d\n",*FIFO_write_ptr);
	printf("fifo write status pointer is %d\n",*FIFO_write_status_ptr);
	printf("//////////////////////////////\n");
printf("reading back the data\n");
for(i=0;i<8;i++)
	//reading data from the fifo
	printf("the output value from the fifo is%d\n",*FIFO_read_ptr);
	printf("fifo read status pointer is %d\n",*FIFO_read_status_ptr);
	printf("/////////////////////////////\n");
return 0;
Like
