Movement detection sensor
christoph-tackChristoph Tack wrote 10/06/2019 at 08:50 • 1 min read • Like
At night, the display will be off, allowing you to sleep in complete darkness.  If you wanted to know the time, you could just wave your hand to light the display.  After a minute, the display will go off again.
I see two possible sensor technologies : PIR & radar.
The RCWL-0516 radar module is cheap, offers 360° detection, but consumes 4mA continuously.
The HC-SR505 PIR module is also cheap, has a smaller opening angle and consumes only microamps continuously.  More info can be found here.  It should work on 3V3, but when I do that, it stays in an eternal detection state.  5V is definitely needed.  A comparison of this PIR sensor to another one can be found here.
Like
