Product Review | Totem 2WD Car Kit
craig-hissettCraig Hissett wrote 10/17/2019 at 16:16 • 4 min read • Like
Billed as an upgradable smartphone-controller car chassis kit, the Totem 2WD Car Kit does exactly what it says; it is a small kit featuring a Bluetooth-compatible board and a companion app to control it. Despite its size the kit comes with everything you'd need to build a fantastic little platform to use as-is or to build upon.
Unboxing
The kit contains the following parts:
Building
Building this kit was great fun! The instructions for building are available by following a QR code on the box. The manual is clear, well thought out and makes assembly as easy as possible. The manual is a tad difficult to read on a phone display so I'd recommend using a tablet or a PC, or downloading the manual as a PDF instead of using the onscreen widget. The kit had a few spare nuts and bolts which was a welcome site, they always come in handy.  I did notice that the tolerance of the small M3 nut/inserts sometimes varied ever-so-slightly, making is sometimes a little tricky to slot them into the beams. Using the butt of the driver tool as recommended in the documentation definitely helps with these parts. The quality of the included tools are also great. Taking time to align the beams properly when attaching the brackets before fully screwing them in is a good method to follow, and ensures for a flush fit.
Finished Build
Software
Once assembled and everything was plugged into the board it was ridiculously easy to get it moving; download the totem app (Link for Android), search and pair with the board via Bluetooth, select the kit you have and start driving! The provided layout gives you the basic controls you need to whizz this thing around, and even has an edit button to allow adjustment.
I would have loved to have seen a USB on board for uploading user written code, but for this size of build the board will already handle everything you throw at it.
I tried some of the other kit controls to see if the commands are the same in all modes and that's not the case. I'm not sure of the board is flashed just to work with the kit its with or if it checks what is connected to it before deciding what it is.
Whatever it does it's a great little drive and the motors are surprisingly torque-y for their size.  If the board handled a higher voltage input it would probably go at a fair speed!
Outcome
The final product is a great little platform! The X3-FBI board features in most of the robot chassis kits available, and as such means there are plenty of extra ports for expansion should you wish to build on top of this chassis. The board could benefit from an on-off switch to ease the wear and tear on the battery connector. Another nice feature for future boards would be a integrated charger for the battery, however I can see why they'd struggle to fit the extra components on the board alongside the rest of the things on there  (the light bar, speaker, position sensor and the motor driver and ports) without sacrificing the small for factor.
The Totem Beam system is absolutely brilliant - the combination of light, plastic beams reinforced with metal inserts and brackets works really well together, and gives plenty of options for building.
All in all this kit was a fantastic introduction to the Totem system. I am really looking forward to assembling my Mini Lab from these guys, and I'm really looking forward to coming up with a custom structure from their Maker Kit too.
Thanks Totem!
Like
