Strange component
hspilhspil wrote 01/29/2020 at 04:10 • 1 min read • Like
Like
lcarter wrote 02/04/2020 at 14:29 point
I think KC is correct, I have sen these under 74xx chips for power supply de-coupling
WestfW wrote 01/30/2020 at 08:45 point
IIRC, 28.07MHz is a "significant" Radio Frequency, so I'm with Ken that it's probably some sort of hybrid filter circuit...
K.C. Lee wrote 01/30/2020 at 04:00 point
Looks like those special decopling caps that was placed under a DIP part. It could also be some thick film resistors/
Augusto wrote 01/29/2020 at 16:32 point
I think it only hast to pins, check continuity between the pins
Donnie Agema wrote 01/29/2020 at 08:42 point
Have you made any measurements?
Jarrett wrote 01/29/2020 at 08:22 point
What does it taste like?
Ken Yap wrote 01/29/2020 at 04:32 point
Some info about where you found it and what material it's made from might help. Also what are the dimensions, especial the distance between pins?
I venture to say SAW filter.
