Recycled Variable Resistors
recycled-componentsRecycled Components wrote 04/03/2020 at 07:33 • 2 min read • Like
This project shows how to make a box for old variable resistors.
You can use old variable resistors from old appliance for the following applications:
Tools:
- voltage reference,
- finding a resistor value for transistor biasing,
- substitute to a real resistor if you do not have one in stock,
- using voltmeter to measure resistance value of resistors.
Devices (variable resistors alone):
- low current power supply.
- cheap light dimmer with bright LED.
Devices:
- offset trimmer circuits for instrumentation amplifiers,
- voltage sources or current source output control,
- filter or voltage controller filter (VCF) frequency control,
- amplifier or voltage controlled amplifier (VCA) control,
- oscillator or voltage controller oscillator (VCO) frequency control.
This is the device that I made many years ago:
Step 1: Attach the Variable Resistors
I used an electric drill to drill the holes:
I soldered the wire to variable resistors with a soldering iron. I made a knot just before inserting the wire into box holes so that is does not disconnect from variable resistor contacts if someone pulls it.
Step 2: Make the Box
i made a box from old transmission wire encasement/boxes/pipes:
I used screws to attach the separate parts of the box.
This could be a good idea if you need a box for an old electronic circuit that you made.
Like
