This website shows you how you can connect two speakers together on a piece of wood.
You can see my device in this photo:
The advantages of such procedure include:
- possible sound effects from:
* speaker sound being blocked by a piece of wood,
* penetrating sound wave mixing with two speakers attach face to face.
- protecting the speakers diaphragms (speaker cones) so that you can put them inside the cardboard or laptop bag.
There is a similar article that I published on Instructables website:
https://www.instructables.com/id/Double-Speakers-on-Wood/
You can see my encasement idea in this YouTube video:
Step 1: Make the Device
You can trying using electric or manual drill to wide the holes before you insert the screws. Using the drill will:
- reduce the chances of cracking the wood with big screws,
- make it easier for screws to penetrate inside the wooden block.
Step 2: Test the Device
You can see another video of my device connected to mobile phone:
Warning: Keep in mind that there is a danger of you burning the audio output because some audio outputs cannot handle low impedance loads (line out). Try Hi-Fi speaker outputs.
