WiFi Touch Switch How to download, install and use the mobile app PINC Technology
pinc-technologyPinc Technology wrote 04/29/2020 at 05:46 • 2 min read • Like
Touch Switch converts your current home to a smart home with wifi interface. Modular touch wifi switch comes with anchor/Roma standard. The smart switch will fix in all the anchor Roma boards and plates. The touch switch is made up of a high-quality capacitive touch sensor. It will supports ewelink/Sonoff app for smart home automation. The wifi modular touch supports the Amazon Alexa, Google Home, IFTTT.
In this video. we are going to show you how to install the eWlink app for your android or iOS play store and configure our modular wifi touch smart switch
Download and install eWlink from google or iOS AppStore.
Register yourself by giving email id and mobile number if you use the first time this app. Make sure that you are in provision mode.
How to check the device is provision mode?
The BLUE LED will blink 3 times per second then the device is in provision mode.
This switch is the combination of the wi-fi and touch. Now you can order this switch from Amazon, Flipkart, Snapdeal, Club factory, etc.
This switch supports Amazon Alexa, IFTTT, google home. This switch operates from 85 volt AC to 265 volt AC with 50 or 60 Hz frequency.
It supports 10 amp of current. The wi-fi is IEEE compliance with b, g,n mode with 2.4 Ghertz frequency. The size of the switch is very small 50X45X24 mm. The wiring of this switch is very easy.
There are only 4 wires. 2 wires are input and 2 wires for the output.
The switch is compatible with the anchor Roma standard which is specially designed for the Indian standard. You can turn this on and off by mobile phone as well as touch.
Like
