What is Boost Convertor
akanzler007akanzler007 wrote 06/03/2020 at 11:04 • 5 min read • Like
Have you ever wondered how high voltage is obtained in Hybrid Electric Vehicles and Lighting system? Also a there have been a lot of situations where we need a higher voltage than our power supplies can provide. We need 12 volts, but have only a 9 volt battery. Or maybe we have a 3.3V supply when our chip needs 5V. Enter Boost Convertors.
It is a simple converter which is used to convert the DC voltage from lower level to higher level. Boost converters is also called a step up converter due to its function. In this guide we will see what is a Boost Convertor, how it works and the applications of it.
Boost Convertor
boost converter (step-up converter) is a DC-to-DC power converter that steps up voltage from its input (supply) to its output (load). It is a class of switched-mode power supply containing at least two semiconductors and at least one energy storage element: a capacitor, inductor, or the two in combination. To reduce voltage ripple, filters made of capacitors are normally added to such a converter's output and input.
Power for the boost converter can come from any suitable DC source, such as batteries, solar panels, rectifiers, and DC generators. A boost converter is a DC to DC converter with an output voltage greater than the source voltage. A boost converter is sometimes called a step-up converter since it "steps up" the source voltage.
Working of Boost Convertor
The main working principle of boost converter is that the inductor in the input circuit resists sudden variations in input current. When switch is OFF the inductor stores energy in the form of magnetic energy and discharges it when switch is closed. The capacitor in the output circuit is assumed large enough that the time constant of RC circuit in the output stage is high.
When the switch is closed, current flows through the inductor in the clockwise direction and the inductor stores some energy by generating a magnetic field. Polarity of the left side of the inductor is positive.
(b) When the switch is opened, current will be reduced as the impedance is higher. The magnetic field previously created will be destroyed to maintain the current towards the load. Thus the polarity will be reversed (meaning the left side of the inductor will become negative). As a result, two sources will be in series causing a higher voltage to charge the capacitor through the diode.
While the switch is opened, the capacitor in parallel with the load is charged to this combined voltage. When the switch is then closed and the right hand side is shorted out from the left hand side, the capacitor is therefore able to provide the voltage and energy to the load. During this time, the blocking diode prevents the capacitor from discharging through the switch. The switch must of course be opened again fast enough to prevent the capacitor from discharging too much.
When a boost converter operates in continuous mode, the current through the inductor never falls to zero. In the steady state, the DC voltage across the inductor must be zero so that after each cycle the inductor returns the same state, because voltage across the inductor is proportional to rate of change of current through it.
Applications of Boost Convertor
  1. They are used in regulated DC power supplies.
  2. They are used in regenerative braking of DC motors
  3. Low power boost converters are used in portable device applications
  4. As switching regulator circuit in highly efficient white LED drives
  5. Boost converters are used in battery powered applications where there is space constraint to stack more number of batteries in series to achieve higher voltages.
The NHW20 model Toyota Prius HEV uses a 500 V motor. Without a boost converter, the Prius would need nearly 417 cells to power the motor. However, a Prius actually uses only 168 cells and boosts the battery voltage from 202 V to 500 V. Boost converters also power devices at smaller scale applications, such as portable lighting systems.
Given below is a list of some of the best Boost Convertors at best price that are used in various applications as mentioned above:-
To explore more such Step-up Convertors Click Here
Like
