Hi there, I am back with another great and interesting project that is a Wireless Camera out of ESP32. Like ESP8266, Esp32 is also a development board with on board Wi-Fi but it has a greater number of pins and some more features additional to the ESP8266 or NODEMCU. In this project we are using an ESP32 chip or metal casing one PCB which is present on development board a Camera Model and some 3-D printed parts. Along this we have also used a SD card module to save the recording on the SD card and also transmit live surveillance on the server which is coded on the ESP32. We have custom designed the PCB for the ESP32 camera along with SD card module. the circuits can be found on the internet and can be designed easily. We have also used a led to provide light in the dark conditions. This circuit on battery and hence it is very important to make it power saving. We have tried to make PCB as small as possible with all the necessary components. No USB to serial IC is given on the PCB as ESP32 can be programmed via its Rx and Tx pins provided. And then when the all the components are soldered, we closed the circuit in the 3-D Model. The PCB was ordered on NextPCB and they provided me the best quality in short time, which is satisfactory. Ordering PCB online in various sites are a step towards developing our own circuit. NextPCB provides very easy😎 and fast delivery🚚 of PCB in different masks and paste with professional look. Also, they send you the picture of your PCB before shipping it to you, Now that very exciting…😃😃👍. #arduino #arduinouno #arduinoproject #arduinomega #arduinonano #arduino duo #ESP32 #Camera Module
