Software Development Life Cycle: All You Should Know
daniamilidaniamili wrote 11/16/2020 at 10:37 • 4 min read • Like
If you’ve decided to order custom software for your company, you need to dive a little deeper into the development details. Since software development is a formidable investment, it requires close collaboration between the developer and the client.
Regardless of the methodology the company is using, it’s up to the client to show their willingness to be involved in the process. The more details you provide about your project, the better outcome you can expect.
Let’s take a closer look at the software development life cycle (SDLC) to give you a better understanding of the development process.
What is Software Development Life Cycle?
The software development life cycle involves producing high-quality software at the lowest cost within a reasonably short timeframe. SDLC is a set pf phases that helps developers produce top-notch software to satisfy the client.
The SDLC includes seven phases:
·         Requirement analysis
·         Planning
·         Design
·         Development
·         Testing
·         Deployment
·         Operation and maintenance
The most common models are waterfall, agile, and spiral. While each model is different, they are all made up of the above phases, which makes the development structure and process easier.
How Does SDLC Work?
The main goal of SDLC is to lower the cost of the development process while improving its quality and reducing the production time. By following a clear plan, it’s possible to remove the typical problems, avoid common errors, and achieve top results for the majority of software development projects.
The SDLC process starts with identifying problems with the existing software, if any. If you are ordering custom software for the first time, the development team may want to analyze the pitfalls you experience with off-the-shelf apps.
Then the team identifies the requirements of the new system. To do that efficiently, the developers must take the time to learn about your company’s needs and requirements. Your initial list of demands may not be complete without a professional evaluation of the entire work process.
The next stages involve careful planning, design, development, testing, and deployment. The SLDC approach is excellent for anticipating costly errors like failing to ask clients for regular feedback. It can eliminate extra expenses while providing top-notch results for the client.
According to experts at Entrance Consulting, SLDC puts a strong focus on the testing phase, which depending on the methodology, can be done on a regular bases. Such focus can help eliminate mistakes timely to avoid formidable expenses. The quality of code is ensured at each development cycle.
What Are the Key Stages of SDLC?
Let’s take a closer look at each of the stages of the software development lifecycle:
·         Requirement Analysis – determines what the app is supposed to do, and what the client’s requirements are. It can also include defining the resources needed to develop the program.
·         Planning – during the planning phase, the development team leader and the client determine the terms of the project. It involves signing a contract, calculating costs, setting a timetable, discussing goals, and the like. Planning must define the scope and purpose of the software and plot the course for the team to develop it.
·         Design – this phase models the way an app will work. Some of the main aspects of the design phase are architecture, UI, programming, communications, and security. Prototyping can also be part of the design phase. It can give the team and the client the basic idea of what the app looks like.
·         Development – this is the actual coding phase. It could be done by one or several developers. Depending on the methodology, the developing process can be done in stages.
·         Testing – checking how well the program works is an integral part of the software development process. Testing ensures that all functions work correctly and catches any bugs or glitches along the way
·         Deployment – at this stage, the program becomes available to the users. This phase can be simple and automated. However, some companies may go through a complicated deployment process to ensure quality.
·         Operation and maintenance – this final stage of SDLC involves watching the way the program works and eliminating any bugs that appear in the process.
Following the SDLC closely simplifies software development and ensures top-notch results.
The Takeaway
SDLC is an integral part of the software development process. It consists of seven stages. Each of them contributes to the quality and speed of development. While the SDLC model applies to several development methodologies, its key phases are similar.
Like
