Chickpeas Can Bell
Used ComponentsUsed Components wrote 02/15/2021 at 05:23 • 1 min read • Like
This article is about a bell made from Chickpeas can.
You can see the bell working in this video:
Step 1: Attach the Washer to Bell
Make a hole and insert the bell sound making washer.
You can see the bell in another photo:
Conclusion
You can try other material types (zinc, copper, iron, tin, solder, aluminium, brass, steel, nickel), other shapes or other amounts of sound making objects to change the bell sound.
Like
