Reviving Simplicity: How the Scamp Embedded Computer is Perfect for Today’s Maker Projects
08/22/2024 at 00:14 • 0 commentsCutting Through the Complexity: Why Scamp is the Ideal Solution for Embedded Systems Projects
The world of embedded systems has seen exponential growth in recent years, with devices becoming more interconnected, smarter, and, inevitably, more complex. This complexity, while driving innovation, has also introduced significant challenges for developers and hobbyists alike. The increasing intricacy of systems, tools, and protocols often means that more time is spent managing complexity rather than focusing on the core objectives of a project. For hobbyists and even seasoned developers, these complexities can detract from the joy of creating and innovating. The more time spent wrestling with these issues, the less time is available for actual development and experimentation.
In response to these challenges, many in the embedded systems community are seeking simpler, more streamlined solutions. The ideal platform should reduce the burden of managing complexity, allowing developers to focus on creativity, functionality, and the core purpose of their projects. Simplicity doesn’t mean sacrificing functionality; rather, it’s about designing systems that are powerful yet intuitive. Efficiency is about optimizing resources—not just in terms of power consumption, but also in how time and effort are spent. Developers want tools that are easy to set up, quick to deploy, and reliable in operation.
Scamp is designed with these exact needs in mind. It’s an embedded computer that brings simplicity and efficiency to the forefront, enabling developers to cut through the noise and focus on what truly matters: building innovative projects. Scamp’s design philosophy revolves around simplicity. It offers a straightforward, no-nonsense approach to embedded computing, stripping away unnecessary complexities. Whether you’re setting up a basic sensor datalogger or a more intricate control system, Scamp’s intuitive design ensures that you can get started quickly, without the need for deep technical expertise or extensive configuration.
With Scamp, the emphasis is on what you want to achieve, not on managing the tool itself. Scamp's integration with FlashForth, a compact and efficient language, plays a crucial role in this streamlined experience. FlashForth is known for its simplicity and power, offering a minimalistic yet highly effective programming environment that allows developers to focus on the core aspects of their projects without unnecessary distractions. FlashForth’s direct and interactive nature means you can write, test, and modify code in real-time, which significantly reduces the development cycle. Instead of getting bogged down in complex toolchains or lengthy compile times, you can quickly iterate on your ideas, experiment with new concepts, and make adjustments on the fly. This immediate feedback loop fosters a more creative and innovative workflow, as you’re free to explore different solutions without the overhead typically associated with more cumbersome environments.
Moreover, because FlashForth runs directly on Scamp, there’s no need for extensive setup or complicated development environments. The system’s simplicity enables you to maintain a clear focus on your project’s objectives, whether you’re working on a small-scale prototype or a more ambitious embedded system. This focus on core functionality means you can bring your ideas to life with less friction, iterate faster, and ultimately create more refined and reliable solutions.
Despite its simple design, Scamp is versatile and can be adapted to a wide variety of applications. Whether you’re developing a smart home device, an industrial sensor network, or an educational tool, Scamp provides the flexibility you need to create solutions that are both powerful and easy to manage. Its range of peripherals on onboard API ensures that you can tailor it to meet the specific needs of your project without adding unnecessary complexity.
See what you can do with Scamp......
Read more -
Agile Product Development with Scamp: Achieving Efficiency in Embedded Systems Development
09/22/2023 at 01:05 • 0 commentsAgile project management is a dynamic and flexible approach that has gained popularity in software development. However, its principles can also be effectively applied in embedded systems development and the creation of new hardware products.
In this article, I'll explore how Scamp and Agile project management complement each other to streamline embedded product development processes.
Agile Product Development: A Brief Overview
Agile project management is characterized by its iterative and incremental approach to project execution. It emphasizes collaboration, customer feedback, and the ability to adapt to changing requirements. Agile hardware development is an approach that adapts the principles of Agile methodology to the design, prototyping, and production of hardware products. It emphasizes flexibility, collaboration, and iterative progress in creating hardware solutions.
Key principles of Agile Hardware include:
Iterative Development: Similar to Agile software development, hardware projects are divided into short development cycles called "spins". Each spin typically lasts a few weeks and focuses on achieving specific hardware and firmware goals.
Customer Collaboration: Regular interactions with stakeholders, including the customer, ensure that the project aligns with their evolving needs. Teams gather feedback at the end of each spin to make necessary adjustments and improvements, which helps in refining the hardware design.
Prototyping: Agile hardware development relies on rapid prototyping techniques to quickly create physical prototypes of the hardware. These prototypes are used for testing and validation. Prototypes may be early versions of the final system, or they may be very simplified designs specifically intended to test a concept or evaluate particular components for suitability.
Modular Design: Hardware is often designed in a modular fashion, allowing for flexibility in adding, replacing, or upgrading components as needed during development.
Design Evolution: The hardware design evolves over time based on changing project requirements and user feedback.
Integration Testing: Frequent integration testing is performed to ensure that hardware components work together as intended. This helps in identifying and resolving integration issues early.
Agile Tools and Practices: Kanban is better suited to hardware development, compared to other methodologies such as Scrum, due to its flexible development cycle and continuous throughput. Teams use Kanban boards to visualize the progress of development tasks and manage work in progress. Regular standup meetings are held to discuss progress, challenges, and priorities.
Time-to-Market: Agile hardware development can result in shorter time-to-market as it enables teams to respond quickly to changing market demands and technological advancements.
Risk Mitigation: By addressing issues early and incorporating user feedback throughout development, Agile hardware development helps mitigate risks associated with hardware projects.
In summary, Agile hardware development is an approach that promotes flexibility, collaboration, and adaptability in the creation of hardware products. It enables teams to iteratively design, prototype, and produce hardware solutions that meet user needs and respond to changing requirements, ultimately leading to more successful and user-centric hardware products.
Scamp's Role in Agile Product Development
Scamp's features and capabilities make it a valuable asset in Agile embedded systems development.
Rapid Prototyping
Scamp's compact size and versatility allow for quick prototyping and testing of embedded systems concepts. It can be used in a breadboard prototype, or it can be connected directly to third-party peripheral modules. As development progresses, custom PCBs can be created to mate with the Scamp, with no changes to software. This aligns with Agile's focus on delivering working increments of a product....
Read more -
Unleashing the Power of Forth in Embedded Systems Development
09/17/2023 at 23:52 • 0 commentsIntroduction
Embedded systems development is a realm where efficiency, precision, and resource optimization reign supreme. As someone deeply immersed in this field, I've had the privilege of witnessing the evolution of programming languages and their impact on embedded systems. Today, I want to shed light on a programming language that has been my trusted ally for decades – Forth. In this article, I'll delve into the advantages of Forth for embedded systems, drawing from my extensive experience as an electronics engineer, R&D manager, and author in this domain.
Scamp3 and Scamp3e Forth computers The Elegance of Simplicity
Forth's unique approach to programming is rooted in its simplicity. It's a stack-based, postfix notation language, which may sound unconventional at first, but it's precisely this simplicity that makes it exceptionally powerful for embedded systems. In the world of constrained resources, every byte of memory and every CPU cycle count. Forth's minimalistic syntax and small runtime footprint ensure that you can do more with less.
Efficient Resource Utilization
Embedded systems often have limited resources, making memory and processing power scarce commodities. Forth's lightweight nature and minimalistic syntax allow you to make the most of these precious resources. It excels in situations where other high-level languages may struggle due to their resource-hungry features.
Total Control over Hardware
One of Forth's standout features is its ability to interact directly with hardware. This low-level access allows you to harness the full potential of your embedded hardware. As an embedded systems engineer, having the capability to fine-tune and optimize every aspect of your system is invaluable. Forth gives you this power without compromising on safety or control.
Rapid Prototyping and Development
In the fast-paced world of embedded systems, time is often of the essence. Forth's interactive development environment allows for rapid prototyping and iterative testing. You can tweak code on the fly and immediately see the results, reducing development cycles and speeding up time-to-market.
Small Footprint, Big Impact
One of the perennial challenges in embedded systems is fitting functionality into a small footprint. Forth's compact runtime and efficient use of memory are instrumental in achieving this goal. It allows you to build feature-rich applications without bloating your codebase.
Real-time Capabilities
Many embedded systems require real-time responsiveness. Forth's lightweight nature and predictable execution make it well-suited for real-time applications. You can meet stringent timing requirements with confidence, knowing that Forth won't introduce unpredictable delays.
Conclusion
In the ever-evolving landscape of embedded systems development, Forth stands as a testament to the power of simplicity and efficiency. As someone deeply involved in this field, I have witnessed firsthand how Forth can revolutionize the way we approach embedded programming. Its elegance, resource efficiency, hardware control, and portability make it a compelling choice for engineers and developers alike.
If you're looking to optimize your embedded systems projects, consider embracing Forth. Its unique characteristics may take some getting used to, but the rewards in terms of code efficiency, resource utilization, and real-time capabilities are well worth the journey. Forth is not just a programming language; it's a paradigm shift that empowers embedded systems developers to do more with less.
Go to https://udamonic.com/index.html and learn more about what Forth can do for you.
Adding MRAM to a Scamp3
03/18/2022 at 00:16 • 0 commentsUsing SPI on a Scamp3 is dead easy, but some SPI peripherals are a little more complicated. This page shows you how to interface an MRAM module to a Scamp3.
Pong in 874 bytes
03/18/2022 at 00:13 • 0 commentsUse a Scamp3 and a Nextion graphical LCD to create a game of Pong in only 874 bytes of compiled code.
See the source code... Game of Pong
Adding a Graphical LCD to a Scamp3
03/18/2022 at 00:10 • 0 commentsAdding a Nextion NX3224K024 touch LCD to a Scamp3...
https://udamonic.com/adding-a-touch-lcd.html
It's simple and quick to get up and drawing!
Scamp - a Forth-based Embedded Computer
11/22/2020 at 00:57 • 3 comments![]()
The story behind this little machine goes back a couple of years. I had wanted to quickly test out a motor control idea, and grabbed an Arduino and a little H-bridge board, and sat down to write some code. The code wasn't hard, and the development process, while not long, took much more time than it should have. I'd spent more time dealing with the IDE and the tools, than in actually being creative. The overhead was much greater than it should have been. It was mildly frustrating, and I pondered how doing "embedded stuff" wasn't as much fun as it used to be. That made me think back to my favourite embedded systems I'd worked with in the past, and what made them nice to use. Consistently, they were all Forth-based machines I'd used in the 80s and 90s.
So what exactly is Forth?
Forth is a compiler, an interpreter, a debugger and, in a fashion, an operating system too. Forth is an extensible, highly-interactive, stack-based language. It is extremely efficient and extremely versatile.
Forth is very interactive. You can type commands in, and interact directly with hardware at a register level. The functionality of the language makes it ideal for debugging both system hardware and software. Forth is typically coded directly in assembly language both for speed of operation and to take advantage of the characteristics of the machine. That makes it very fast. Forth is unlike any other conventional programming language.
Commands (known as words in Forth) get an immediate response. This, coupled with Forth’s ability to talk directly to hardware, makes it an excellent environment for embedded system applications.
Forth words are the equivalent of functions in C, Python or Java, or subroutines in assembly language. Forth allows the execution of any word in isolation from the command line. Thus, words can be independently tested and verified outside of the main application. So rather than writing a single, large program, small segments of code are written and tested independently (and interactively). These words are then combined to create new words, eventually ending up with a single word that is the whole application. This new word is also available to the developer, and in this way the language both grows and becomes richer as the developer works with it. In addition, the words used to create the new word are still available and can be run as programs in their own right, or used to create other new words. Forth is both versatile and powerful.
So why is Forth not widely used? It's very powerful, and the development process is much faster. But, you can't write sloppy code with Forth. It's not forgiving. You really have to think about what you're trying to do. This isn't a bad thing, because invariably you will come up with a solution is that is tighter and more robust.
Hardware for Forth
With fond memories of Forth in mind, I looked around at what off-the-shelf, forth-based embedded systems might be available now. Answer ... none. There are several varieties of Forth kicking around, as source code. And these can be ported to various dev boards or other embedded systems. But there was still effort involved in getting Forth running. Granted, it's not hard (well, mostly). For someone just wanting to try Forth in an embedded context, or someone completely new to embedded systems, this presented a barrier to entry. Why can't you just buy a Forth-based machine off the shelf and start using it? To me it seemed an obvious thing.
I decided to design and produce a small embedded machine with Forth preinstalled. I selected FlashForth, written by Mikael Nordman, as the Forth environment. The first hardware version was in a DIP form factor, similar to an Arduino.
I quickly came to the conclusion that the breadboard wasn't always necessary, and so the form factor of the machine changed. By using a single inline connector on the underside of the PCB, modules...
Read more
